Question about Samsung Gravity SGH-T459 Cell Phone
That's my problem too!
When I push down hard as I slide, sometimes the spring doesn't stickout, but that's doesn't always work and it only lasts for one slide. I'm worried I'm breaking my phone, not fixing it!
2 Suggested Answers
blodwen
  • 8 Answers
SOURCE: light sensitive buttons not working
I had simmilar problems, re-setting the phone was no help.
I had to replace the flex cable that connects the screen to the main board in the end and phone now works perfectly.
Nick
Posted on Oct 16, 2008
How can I remove Watch's links?
the links may have spring loaded pins. Use a very fine flat screwdriver and pry inward slightly to pop them out. Some have holes in the side where you can use a straight pin to push them in.
Dec 22, 2014 | Watches
Why do no panel lights turn on when my Kenmore Model 587.1625 is latched and ready
The door latch in Kenmore and Kitchenaid isn't of the best design.The spring steel latching tab is needs to push down the black plastic slide mechanism when the door in closed. That slide pushes down on a micro switch which interrupts the cycle when you open the door when the dish washer is running. Take the latch assembly back out. You can insert two compression springs inside the slide on each side of the latch. They are approx 3/16 Dia x 3/4 to 1 inch long. In the hardware dept at Home Depot or Lowe's..The springs will push the slide down hard enough to activate the switch. Right now your dish washer thinks the door is open.
May 17, 2014 | Dishwashers
Installing push rod
last time i check, i dont remember a spring connecting to a push rod. usually a push rod slides into the push rod galley until it hits the valve tappet.
Oct 20, 2013 | Husqvarna Garden
My rexel stapler does not work, any help[
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Sep 11, 2012 | Office Equipment & Supplies
Electric window motor doesn''t work needs replacement
Remove the visible bolt from the left side of the arm rest.
Remove the window switch/door lock/mirror controls by popping the entire panel out, may need to use a flathead screwdriver.
Slide panel off of door.
Pull vapor barrier loose on the bottom right side. This will expose a coiled spring and window motor. Tape the window in the up position using masking or packaging tape.
Mark a straight line across the coil spring, to help with realigning the new motor.
Use tool j-38864 connect it near outer part of coil sprint where it hooks to retainer or in a pinch use pounted vice grips at same location ensuring they are firmly locked on spring.
Force spring clockwise to disengage it from it's retainer point.
Pull spring slightly outward just enough to clear the retainer point and slowly let it uncoil counterclockwise.
Disconnect wire connector from right end of window motor.
Push the three plastic retainer points outward as you lift up on window motor to disengage from retainers careful not to break the plastic retainers comes out pretty easy
Install new motor into the plastic retainers, make sure it is fully seated.
Reconnect wire connector to new motor.
Use J38864 or vice grips to recoil spring, reseating it to retainer point as before.
Remove tape from window and test up/down switch.
Reseal vapor barrier in place as it was before.
Slide switch control back up through hole in door panel from where it mounts and slide door over the door handle.
Align retaining clips to holes and push them home with gentle raps of your hand start at the top and work downward on panel.
Replace the bolts in the arm rest and pop back in the controls.
Mar 04, 2011 | 2000 Pontiac Montana
The last spark plug on 1998 isuzu trooper i changed the plug but now i cannot get the boot slide oto the plug properly is certain why to do this or maybe a little vasoline on the boot slide in better
has the small spring clip gone?if you push it downn hard and it stays loose then you may have to replace that wire(if replacing all wires take them off ONE at a time)
Sep 22, 2010 | 1998 Isuzu Trooper
2004 Toyota Sienna power slide door won't open all the way
The suggested fix above did fix my problem. The problem is that a 2.5" hinged finger that pops up from the floor of the door opening to block the door. Apparently, the finger should, but doesnt go back down after the gas flap is closed. Even after I got hinged finger down (so that the sliding door would open/close all the way), it still would not go back down after the gas flap has been opened. i.e. I have to push the finger back down every time after we fill up with gas. It looks like there is a little wire/spring that should pull the finger back down, but it is off of the finger. I think that replacing this back on the finger should fix the problem permanently.
Mar 16, 2009 | 2004 Toyota Sienna
I have the roper Model: RTW4100SQ, and it would seem that a spring that keeps it balanced has come off and now sits to one side i am in need of knowning how to a)open top b)see and reatach spring or any...
To access internal components, REMOVE POWER, lift the console by one of three ways. 1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward. 2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw. 3. insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
There should be a counterbalance spring in the bottom rear of the machine. Sometimes the mounting hole in the frame will rust through..if so drill a hole next to old hole and reattach spring. Sometimes spring will rust and break..is so replace spring.
If you need further assistance let me know
Regards,
reg501
The FixYa Team
Jun 19, 2008 | Roper Washing Machines
Lever won't stay down Breville CT20
hi sounds like the problem is the holding down mechanizem clean the toaster well find that spring which caches the lever down you can find it on the external lever side pretty small and simple thing when you push down the external lever the spring kick a little lever which holds the slide in place for heatup only when you will hear a "click" then you'll know its in place and then the electric cicuit will be close and engage the coils to heatup good luck
Mar 30, 2006 | Breville CT20 Retro Classic 2-Slice...
Samsung Gravity SGH-T459 Cell Phone Logo
27 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
