Question about Compaq Computers & Internet
My presario 1600 just beeps when I turn it on...
My presario 1680 just beeps when I turn it on... Beep...Beep Beep Beep...then repeats beep pattern
When I turn on my Vostro 3750 first thing in the meeting, the key board lights up, the fans start but it just beeps twice every 15 seconds. I go through this process about 20 times before I can get it to start up. Dell are not coming up with any answers on this problem.
Posted on Dec 06, 2011
  • 119 Answers
There are 4 kinds of beeps that the pc produce when you turn it on, base on your beep it is indicating that the memmory is damage,
a single beep means the pc is ok
and your beep is memmory damage
a long beep pause and then beep long again means video card damage
if the beep sound like a firetruck the processor or memmory is over heating
Posted on Sep 24, 2009
I have a quanta 3082 MB in a HP Pavilion zd8230us laptop when I startup it beeps constantly got any ideas? anyone
The beeps with have a pattern to them. Listen closely when you first turn the laptop on and listen for the pattern. It might be something like 1-3-2 (1 beep, wait, 3 beeps in a row, wait, 2 beeps) It will repeat for listen for a bit to make sure you have the correct pattern. Once you have that pattern got to the HP webpage, in the support section, in the search type in "beep code errors". It will give you a list of beep patterns and tell you what the problem is. It could be the RAM, it could be another problem with the motherboard; those codes are what you need to have first.
Dec 24, 2014 | HP Computers & Internet
I press the start button and it starts to peep
The beep pattern indicates a specific problem at startup.
here's a list of the common beep codes (scroll down to beep and led code descriptions).
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07107#N516
Identify the issue and add details for further information.
Jul 11, 2014 | HEWLETT-PACKARD Compaq Presario SR5518F...
Slow start up and beeps a couple of times
The beep pattern tells you what is wrong. Search Google for the exact pattern...ie 2 short beeps, 2 long beeps, etc. Could be bad RAM chip or bad motherboard or video card, etc. The beep pattern will tell you what needs to be fixed.
Mar 25, 2014 | HP Compaq Presario R4000 Notebook
Loud beeping
Beeping is usually an error. The beeping is usually a pattern, so count the beeps and google it; beep code *** and you should get an answer.
Feb 02, 2014 | Compaq Presario Notebook
My compac presario PC SR5510F keeps beeping and wont start up? do you know why that would be
When a PC is turned on and then starts beeping, the beeps are actually a message to help troubleshoot. You should listen to the beeps and learn what the pattern is. With that pattern, you may be able to determine the issue.
HP has published a list of these beep codes that are common to many of their system. That information can be found at this link > HP/Compaq Beep Codes
Feb 03, 2011 | HP COMPAQ Presario SR5510F Athlon 64 X2...
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
Beep codes single long beep repeating
Different PC manufacturers have different BIOS Boot codes.
Read first
http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Then read:
http://www.pchell.com/hardware/beepcodes.shtml
http://www.computerhope.com/beep.htm
http://networking.ringofsaturn.com/PC/beep.php
Mar 10, 2010 | HP Compaq Presario SR2010NX PC Desktop
Consecutive beeps last 10 seconds, silence for 5 seconds, the long beep for 10 seconds...pattern repeats. Nothing comes on screen. I removed single RAM card, tried other slot, same problem. I powered it on...
how many beeps any breaks between beeps and then how many like 3 beeps then stops for 1 sec then beep beep beep stop beep beep beep check to make sure that your installing your memory sticks right and they are seated all the way make sure all cards are seated right all wires are not shorting out and a worst case your cpu is good
Dec 25, 2009 | Biostar K8VGA-M Motherboard
Spilt a drink
I don't know if I can solve this here. But the beeping noise is your pc trying to tell you what is wrong with it. Somewhere there are pc beep codes. http://www.pcstats.com/articleview.cfm?articleID=1223 If these can't help you just put "computer beep codes" into google. Here they are:
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Dec 08, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
908 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
