DVD drawer won't open - there is not a dvd inside.Last night I played a dvd successfully. It did not have a label on it on anything that could result in something getting stuck.
  • 456 Answers
In my expertise the smallest issue from an out of allignment issue with the drawer to a faulty spindle motor that spins t oo fast. The best bet and what i would do is either remove the drive and make sure everything is sliding ok, and if no obvious fault can be found(loose belt slipping gear etc) i would replace the dvd drive of the unit. Good Luck.
Posted on Sep 24, 2009
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
Panasonic dvd home theatre system SA-HT520. My 2 year old was playing with buttons on dvd player and now when i press open/close button it is saying locked and won't open, is there anything i can try...
The system has a locked / unlocked toggle sequence on the main unit by holding down stop (or Play) and then tapping the power button. Use this sequence lock or unlock the DVD / CD drawer.
Sep 29, 2011 | Panasonic Home Theater System System
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
Dvd tray wont open
Hello
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
6. You might need to see a technician.
GOODLUCK
Jan 27, 2011 | Amphion Mediaworks S99 DVD Player
The DVD door will not open when the button is pressed
Please check the bellow instructions:-
Turn off your DVD player. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Please get back to us if you have any further query or else accept the solution.
Nov 01, 2010 | Panasonic NVVHD1BS DVD Player / VCR Combo
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
The DVD drawer will not open on the model TT 320
Hi
Thanks for using FixYa. Please locate the DVD player’s manual eject button which is a small hole located underneath the DVD drawer. Now insert a stiff wire like a paperclip or safety pin into the hole and push gently to open the drawer. Now pull the drawer gently to open it. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling then you need to remove the label. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player and you need to have it serviced.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | TruTech TT320
DVD drawer will not open on Zenith ZHX-313....help???
hi friend,
Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs. If this is the case you should have it serviced or perhaps it is time for a new one.
I hope this helps.
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | Zenith ZHX-313 System
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Electro Med Services...
