Question about Dryers
There is no heat in the dryer. I just changed out
There is no heat in the dryer. I just changed out the heating element and still no heat. I checked the breakers and they are not tripped. What next?
    President:
  • 1,776 Answers
Check for a blown thermal fuse. It's about an inch long and is usually located inside the rear of the dryer attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a blown thermal fuse. Sorry for your trouble and best wishes.
Posted on Sep 24, 2009
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Samsung heating elements dv206aes (dc47-00019a part). i would to know the step by step on how to replace my dryer heating elements. thank you. pam
Hi
Please check the bellow links to get the step by step instructions to replace heating element in your dryer:-
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
http://www.wikihow.com/Change-the-Heating-Element-in-a-Dryer
http://www.ehow.com/how_4819467_replace-dryer-heating-element.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 01, 2011 | Dryers
NO HEAT . I CHANGED THE HEATING ELEMENT,
Check to ensure you have 220v A/C to the dryer.
The dryer will run on 110v but will not heat.
Ck. the dryer cord where it connects to the dryer.
Some times one of the terminals on the cord may have burned up due to a bad connection.
Electric dryers are not sold with power cords since there are several different types of 220V outlets.
You may have a bad house fuse, Circuit breaker or 220V outlet.
Jan 16, 2010 | Dryers
Not getting any heat in my dryer.
mam if the drum is rotating and not getting heat then the problem will be in the heating element please change the element.before changing please check the power supply across the element terminals.
Sep 11, 2009 | Dryers
Dryer has no heat
either your heating element or your thermostats are bad. on the heating element casing there are two thermostats. check the top one for continueity if it doesn't have continueity the change both thermostats. if they are good then check your heating element for continueity. after you get your dryer heating then clean out your vent system... if it's not venting properly then your dryer will take a long time to dry.
Jun 16, 2009 | Frigidaire Dryers
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
My maytag electric dryer will not heat up. it's a de107
Have someone check to be sure you have 240 volts to the plug. The dryer will run on 120 volts but must have 240 volts to the heating unit. If you 240 volts you probably need a heating element or control.
Apr 06, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
The dryer works but does not heat
Before you buy an expensive heating element change out the thermal fuse. It's only about 15 dollars for a fuse as opposed to around 100 dollars for a heating element. Both can be purchased at a appliance repair shop. The thermal fuse is usually located near the heating element housing and has two wires coming off of it. Make sure you unplug the dryer first though. If the thermal fuse if dead then your heating element will only heat for about a second or two at a time. The way to check this is to open up the dryer so you can see the heating element. While it's running watch it and it the heating element comes on and then turns off then the thermal fuse is bad. If it doesn't come on at all then the heating element is bad. Wait a good 5 minutes though before determining if the heating element isn't coming on. Sometimes it takes a bit before it engages. I hope this helps you and if you have any more questions feel free to ask me. Good luck.
Jan 08, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore dryer
change the thermal limiter its the tiny disc on the heater element pan and check for 220 at the outlet dont assume because its running you have full power to it
Mar 13, 2008 | Dryers
Dryers Logo
Top Dryers Experts
