Question about Dryers
No heat on kenmore dryer 110.66732501 tumbles fine, circuit breakers ok
  • 5,911 Answers
The following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Sep 24, 2009
I have a Kenmore Dryer model #110.66732500 that just quit heating. Everything else is working fine, tumbles but no heat. It is 4.5 years old. When it quit it tripped the circuit breaker, we reset the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
bn
Sep 28, 2010 | Kenmore Dryers
Dryer portion on my stackable does not heat up.
Hello there:
please try these solutions and keep me informed on how this is going for you ok
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Dried a load fine, next load tumbles wont dry. still cant get heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Kenmore 63942 Dryer
HE3t Kenmore dryer runs fine but suddenly stopped producing heat
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Kenmore Dryers
No heat gas kenmore gas dryer
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
Dryer will not heat up and heating element is fine ?
Hi
Power from the house-- Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element-- Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse -- On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring -- A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
May 12, 2009 | Kenmore Dryers
My Kenmore electric dryer model# 64652400 is not heating.
Hi
Fuses Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Please revert for further assistance and Do rate the solution as FixYa if found useful.
Thanks
Rylee
Mar 16, 2009 | Kenmore 64652 Electric Dryer
Kenmore dryer
Hi!
Heating element
Thermal fuse
Wiring
Heating element
Thermal fuse
Wiring
Do rate the solution as FIxya if you find this solution helpful.
Thanks
Rylee
Mar 15, 2009 | Kenmore Dryers
Dryer won't heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Aug 11, 2008 | Kenmore 74832 Gas Dryer
Dryers Logo
277 people viewed this question
Top Dryers Experts
