Question about Dryers
Elec dryer, no heat case
I am working on an electric whirlpool dryer m# LER4634DQ1 S# MS0809482. This unit operates on 240 Volts.
I took voltage measurements as followed: I connected my black lead to ground, and measured with the other lead at one side of the termal cutoff swt, which measured 120v. I tested the other side, and that also measured 120v, with idicates that the side was good, allowing voltage to flow through. I then measured the other swts by using the wiring schematic, until I made it to the heating element. All measurements read 120v on one side of the swt, as well as 120v on the other side of the swts, just like the thermal cutoff. When I got to the heater, I measured 120v at both terminals, which to me confirmed that I had 120v at L1, and 120ov at L2, totaling 240v. I then measured at the heater terminals with "BOTH" leads, and mesured zero volts with the leads connected... My questions are: Should I have measure 240v there at that time? I did disconnect the wires, and then connected my meter leads, which displayed 77 volts... That was odd. After that, I ohmed out the heater, and found 9 ohms... According to the diagram, the ohms should be between 7.8 - 11.8 ohms... So what are yours thoughts? Do I have an open heater, even though I measured some resistance? After all, I did measure 120V as I tested the circuit by following the schematic... Please help?
Thank you in advance.
    President:
  • 1,922 Answers
Check your center NEUTRAL connection to the element,sounds like your losing it somewhere,certain units rely on the neutral to operate the element on certain cycles to dry, the neutral carries the imbalance current load and the wire gets hot and will get brittle and break
Posted on Sep 24, 2009
New GE Profile dryer DPSE810EG7WT does not work. I wired exactly as old dryer. L1 L2 and neutral. The timer comes on but the machine does nothing! Thanks, Roger
if this is a gas dryer you would only need L1 OR L2.... NOT BOTH PHASES, this unit only needs the one leg of either A 120Volts or B 120Volts phase NOT BOTH PHASES 240 volts A.C. not 240 V.A.C. as in an electrically heated element will require to heat the system, NOW ...be careful now because one hot phase is connected where it shouldn't be!!!!
Apr 26, 2010 | GE DCVH515GF Gas Dryer
No heat dryer ler8648pwd
first check the power supply to the machine make sure you have 240 volts ( the motor, the timer, the lights all work on 120 volts and the heater is the only thing that needs 240) if you have 240 volts to the unit then check your thermal fuses and the heater element to see if they are good they all will "ohm out" which means 0 ohms or they read all the way through them
Apr 05, 2010 | Whirlpool LER5636P Electric Dryer
My ge gew9250p dryer heating element is needing replacement what is a good part number for this
Hello there:
this should help you out ok
See Part # 14 on diagram.
or
See all parts for this section / diagram Heating Element (11" long x 5" wide) (Heater Element) This heating element fits later model Whirlpool/Kenmore brand electric clothes dryers. Each of its two terminals measures 5/16 of an inch, while the unit itself is approximately 11 inches long by 5 inches wide. This element carries 5200 watts and 240 volts. Appliance Help Part Number AH344597 Availability: In Stock Compare At: $56.32 Your Sale Price: $46.93 You Save: $9.39 SALE PRICE:$46.93 -->
Nov 22, 2009 | Whirlpool GEW9250P Electric Dryer
Whirlpool GEW9200L not heating up, i have replaced th thermal fuse, thermistor, heating element, thermal cutoff and high limit. What next.
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
Oct 05, 2009 | Whirlpool GEW9200L Electric Dryer
Have a Whirlpool Dryer Model #: LWE5700W0. Does not produce heat. Likely needs new fuse. Where is fuse on dryer located?
more than likely its your heating element, but you can first check and make sure you have 240 volts to the unit from the house panel as for fuses there are none inside the unit
Sep 17, 2009 | Whirlpool LEB6300 Electric Dryer
Dryer works but only on medium heat. which element is bad?
you could either have 1/2 of the element out(check with ohmmeter) missing one leg of your 240 volts input if dryer uses 240 for operation or an input power wire ib burned off somewhere inside unit, check the "NEUTRAL" connection at the heating element center point, it carries the current im-balance and is subject to a lot of heat from element case
Aug 01, 2009 | Whirlpool WGD5300S Dryer
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
WHIRLPOOL DRYER GOLD GEQ9800PW1 HOW TO MAKE IT WORK WITH 220 VOLT
ck frequency on tag if US will be 60 cycles ..most overseas areas are 50 cycles ..not gonna work without some sort of converter
Nov 17, 2008 | Whirlpool GEQ9800P Electric Dryer
Ler662
CHECK FOR 240 VOLTS AT DRYER ELEMENT WITH DRYER
RUNNING IN HEAT CYCLE. IF NO VOLTAGE, CHECK WALL
OUTLET FOR 240 VOLTS BETWEEN LEFT AND RIGHT SLOTS IN RECEPTACLE. A DRYER WILL RUN ON 120 VOLTS TO
GROUND BUT WILL NOT HEAT IF 240 VOLTS IS NOT PRESENT. IF THERE IS 240 AT THE OUTLET, START TRACING THROUGH THE HEATER CIRCUIT. LOOK FOR A FAILED THERMOSTAT OR THERMAL FUSE NEAR THE HEATER OR EXHAUST OUTLET. CHECK THEM WITH A CONTINUITY TEST WITH DRYER UNPLUGGED, OR A VOLTAGE CHECK WITH A HOT CIRCUIT.
Jul 28, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
188 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
