Question about RCA DRD430RG DirecTV DTV Receiver
Cable not working!!
My cable box is no longer sending any signal to my TV. The small light on the front of the receiver is blinking on and off, non-stop. Does that mean something? What is wrong with it... how do I get it to start working again??
  • 129 Answers
Good day.
Try to check first for the wiring connections from your cable modem to your TV . Then pull out the plug of your cable modem from the outlet. Leave it be for 5 mins and then plug again.
chris
Posted on Mar 12, 2008
Sylvania LC427SSX worked fine until comcast upgraded the cable box cable modem. TV works with DVD player but not with the cabe box. Could this be a firmware issue that requires me to upgrade the software?
In my area, Comcast has blocked all free watchable basic channels. You now need a very small but special box to receive those. If it's a conventional cable box, you might have to call them to send a signal to reset it.
Feb 14, 2014 | Sylvania LC420SS8 LCD TV
Toshiba 50HX81 projection 'tv- blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jan 27, 2009 | Toshiba 50HX81 50" Rear Projection...
Blinking light front of TV
You need to set the clock. The timer is confused if it dose not know the time.
Jan 19, 2009 | Quasar VV-2002 20 in. TV/VCR Combo
Blinking timer red light on jvc tv, no other functions
Dec 27, 2008 | JVC AV-32230 32" TV
Light blinking on tv
Dec 04, 2008 | JVC HD-56G787 Television
Timer blinking all the time can't turn TV ON.
Oct 29, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Toshiba 46H84 tv turned off light blinking
Sep 17, 2008 | Toshiba 46H84 46" Rear Projection...
Timer light blinking
Aug 21, 2008 | Mitsubishi WS-65819 TV
Blinking red light no picture or sound
Jul 18, 2008 | Toshiba 36A43 36" TV
Turned off by itself, blinking red led at front
The clicking sound is the internal protection switch that kicked in because a fault had been detected.
First ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Jun 28, 2008 | Toshiba 42HP95 Television
RCA DRD430RG DirecTV DTV Receiver Logo
192 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
