Question about Baby Gear
How do I remove the cloth to clean it? - Baby Gear
  • 164 Answers
Your not suppose to...if you ever take the cover off its not as safe....It may sound bad but your only to spot clean a car seat.
Posted on Sep 24, 2009
How do I clean the LCD/LED screen without smudging or leaving a water mark
Hi Herkandjen,
Most TV companies recommend only a dry cotton cloth for cleaning the LCD screens. My personal experience is that using a mildly moist clean cotton cloth is the best thing for this purpose. For tough oily marks MILD soap solution can also be used in place of water. Please be careful to apply only very mild pressure while cleaning. Never ever spray the screen with any kind of liquid. Because the liquid if seeped through the plastic frame can damage the electronics inside. Happy viewing.
May 10, 2015 | LG Televison & Video
Tip
How to clean electronic equipment
<li>Unplug any cables or power cords from the electronic equipment before working on them. Remove any component cables leading to other devices.<br /> </li> <li> 2 Wipe down the electronic equipment with a soft damp cloth starting at the top of the device and working downwards. Wipe away any accumulated dust, lint or dander.<br /> </li> <li> 3 Use a small amount of isopropyl alcohol on a soft cloth to remove fingerprints from any CDs or DVDs. Work from the center of the media outwards. Do not rub too hard or in a circular motion.<br /> </li> <li> 4 Clean a LCD television or <a href="http://www.ehow.com/computers/">computer</a> monitor screen by wiping a damp cloth gently across the screen once all power is disconnected. Wipe down the ventilation area to remove any dust. Clean the base with the same cloth.<br /> </li> <li> 5 Open a computer case by removing the screws that hold the side in place. Blow dust and debris from the interior with a can of compressed air. Start at the power supply and blow through the rear ventilation fan. Continue to dust the motherboard, component slots and case.<br /> </li> <li> 6 Insert a compact disc cleaning disc into CD and DVD players to better clean up these electronic devices from the inside. This cleans the interior lenses, removing dust accumulation that can lead to early device failure.<br /> </li> <li> 7 Rub down an MP3 player with a soft cloth and a small amount of ammonia-free glass cleaner. Use a cotton swab to get into crevices and hard to reach areas that trap debris.<br /></li>
on Dec 16, 2010 | Audio Players & Recorders
What's the best way to clean a tv screen
Mild soap and water with a microfiber cloth with TV off. Then I wipe only water on the cloth to remove any residue then quickly dry with a dry microfiber cloth.
Sep 06, 2014 | Televison & Video
Paper jammed in the ADF and can not pull out or remove.
Required tools... T10 screw driver, cloth, tweezer, water
Remove ADF input tray, open adf door, remove connector, remove T10 screws, lift the adf mechanism, remove the paper, observe why paper got strucked, shoot the problem, clean the mechanism & sensors with cloth, fix the machanism back..Dip cloth in to water sqeeze it, clean adf pick up roller with it. fix all spares back,..Check..
Sep 14, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
How do you clean the soleplate? I have some residue/buildup that does not wipe off. I already did the self-clean to remove deposits but there is still "stuff" on the soleplate
You can use Rowenta Sole plate Cleaner. If you cannot find it locally, check online at retail sites like Amazon.
If you want to try a home made cleaner, Avoid abrasive cleaning powders or scouring pads.
Begin with a cold iron that is unplugged from the electrical outlet. Use a mild dish washing soap or laundry detergent to create a sudsy solution. Use a nylon mesh pad, sponge, or a clean cloth dipped in the solution to completely wipe off the soleplate of the iron. Wipe the soleplate clean with a damp cloth or rag.
If the soleplate is the victim of a starchy build up or corrosion of some form, you will need to use something a little stronger. Use a clean cloth dipped in white vinegar to remove the build up. Wipe the soleplate clean with a cloth dampened in clean water.
If this does not work, then you will need to heat a solution of white vinegar and salt until the salt dissolves. Using a clean cloth sipped in the heated solution, wipe the iron's soleplate clean. Continue wiping until you have removed all of the build up or corrosion. Remember to wipe the iron completely clean with a cloth dampened in clean water.
Let me know if you have any other questions. Thanks.
Read more: http://www.doityourself.com/stry/cleaniron#ixzz1L4J0N8Yh
May 01, 2011 | Rowenta DZ1700 Iron
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
Apr 20, 2010 | Rowenta DX6700 Iron
There are stains in between the glass on the door. How can I remove and clean this?
Hello :
Disassembling the door yourself will void the warranty and may require a service technician to repair any damage or put the door back together. It is recommended that a service technician complete this for you. It is not recommended that you disassemble the door yourself.
Things You Will Need:
Glass cleaner
Soft cloths
Glass stovetop cleaner
Steps to Remove the Glass:
Make an appointment with a service technician to remove the glass from the door.
Use glass cleaner to remove as much of the debris as possible.
For tougher stains and food debris, use a glass stovetop cleaner to aid with removal.
Once the stains and debris are removed, allow the service technician to reassemble the door.
Cleaning Through the Door Vents:
When the glass cannot be removed or is no longer covered by the warranty, there are other, more creative, ways that can be used to clean it.
Long handled cleaner
Bottle brush
Yardstick/ruler wrapped in cloth
Bent hanger wrapped in cloth
Dryer vent brush
Glass cleaner
Soft cloths/towels/long socks
Duct tape (optional)
Steps to Clean Between the Glass:
Some Microwave ovens have small vents along the bottom or top of the door. These vents go in between the glass (and are likely part of the problem with other materials getting in there as well). By inserting a towel on a long-handled stick, you can gently clean between the glass without disassembling the door.First, find the vents on the door if you have them.
It may be easier to remove the door from the hinges and lay it flat on the floor. Many microwave oven doors simply lift right off of the hinges, others will require loosening a few screws first. Replacing the door should be easy to do at the end of the cleaning and will not void the warranty.
Start by choosing a long-handled cleaning tool. There are a variety of options available, so be creative.
Secure a towel or soft cloth (long socks work well) to the handle with duct tape or other strong tape. Make sure it’s well fastened so it doesn’t come off and become stuck in the door.
Moisten the towel or soft cloth with the window cleaner or other cleaning product.
Insert the cleaning tool through the vents.
Move the cloth back and forth to remove the debris from between the glass.
Remove the cloth.
Repeat with a clean cloth until all of the debris is gone.
Replace the door on the oven and enjoy the clear, clean view.
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Whirlpool MH7140XF Microwave Oven
What is the recomended maintenance for this machine
check and clean the feed rollers at paper feed with cloth and water or cleaning fluid remove drum unit and check the condition of the foil on drum for dents or marks.. clean the rollers at pressure roller and clean this off with spirits and soft cloth(rollers under the drum) empty out the master waste treay and clean off rollers here with spirits and cloth and check nozzle at air blower to the left of drum (Yellow nozzle for damage and blockage.. then check the tension of the master feed roller and clean the thermal heads with a soft cloth..remove the scanner glass and clean both sides with glass cleaner and clean off the lamp unit mirrors(take care here you dont miss align on guides)
Nov 05, 2009 | Riso RZ220 Duplicator
Hp photosmart 2610 not recognizing new color printer cartridge (97)
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | Office Equipment & Supplies
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
Baby Gear Logo
166 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
