Question about Dryers
How to repair squeeky dryer? My dryer squeeks a lot, it is an older GE with a porcelian drum. Is it work repairing?
  • 5,911 Answers
It may be worth repairing. GE dryers generally have drum glides that keep the drum quiet while it is spinning. More than likely the glides have worn out and now you have metal on metal scraping. If you post back with your complete model number, I can see if I can locate a part number and a price to give you an idea of what it might take to repair the dryer.
Posted on Sep 24, 2009
Squeeky dryer
if the squeeks are coming from the tub while turning. it may be the front tub glides. but the dryer will need to come a part to fix them. good-day ! more possible symtoms-- Damaged Drum Wheels, Deteriorating Drum Bearing, Failing Idler Pulley Wheel, Loose Belt.
Mar 08, 2012 | Frigidaire Dryers
Squeeking when on
check drum roller and glides Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
May 29, 2011 | GE DBXR463EDWW Electric Dryer
Dryer makes a squeeking,or "chirping" noise while
Most likely the problem is the drum rollers are in need of lubrication.
Lube the drum rollers and this should solve your noise problem
Jan 05, 2011 | Maytag MDE9700AYM Electric Dryer
Squeeky dryer
belt is stretched from a worn bearing in the belts idler pulley
Replace the belt along with the pulley sold at most Sears stores
Jun 20, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My roper dryer is squeaking. how do i stop this
you would have to see if the motor or something else is squeeking. remove front panel, take belt off motor, use a no heat cycle, and turn on machine. any squeeking? yes? then you need a motor...no? then you need a repair/maintnance kit for you dryer. it comes with new rollers, belt and tension pulley and this should get rid of all potentall squeeky parts. if you give me a model number then maybe i can get you the part number you need.
Mar 21, 2010 | Dryers
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2009 | GE Dryers
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Loud squeeking sound. Figure its the back
Well I do not know which brand you have but I have pictorials on all kinds of dryers at my website. I am guessing yours is a GE. Check out my repair PICTORIAL.
Note: Not pictured is a WE3X75 bearing that goes on the rear of the drum and fits into the center hole pictured above.
WE3X75 drum bearing.
Jul 06, 2009 | Dryers
Squeeky Noise
Raise top by prying lose clips on front, remove 2 screws holding front in place (inside cabinet) and disconnect wirings, removed front (panel with door) panel, removed 4 screws holding inside front panel in and lifted it out, released tensioner from belt, lifted out drum out of unit, vacuumed accumulated lint from machine, motor, wiring, checked and greased drum rollers and tension pulley, cleaned drum edge from accumulated roller debris using automotive brake rotor cleaner, reintsalled drum, applied automotive belt dressing to belt and reassembled. Working for now. If reoccurs I will replace drum rollers and tension pulley.
Nov 22, 2008 | Maytag MDE4806 Electric Dryer
Squeeky noise while baking
If it is a fan oven then it could be a noisy fan bearing
Nov 17, 2008 | GE Ovens
Dryers Logo
98 people viewed this question
Top Dryers Experts
