Question about Sony Xplod XM-554ZR Car Audio Amplifier
Is it my amp or sub
Sound from my sub lasts only 5seconds before fading away..
amp light is green and stays lit and all wires are connected.
so there must be something im doing wrong.
    Sergeant:
    Champion:
  • 231 Answers
Try another sub if possible to see whats happening...You might want to check to see if you have a good ground to amp .make sure ground connector is not on top of paint..if it is scrape paint off from body and polish to bare metal.Then reattach ground wire..then retry..
Posted on Dec 24, 2007
04 Road King light fading
You have either a green corroded wire in the wiring harness, or a short in the headlamps/running lights. It is much easier to find if you have an electronic circut tester. If not slave away with your test light, hooking both to ground terminal to check for power, then reverse to positive terminal to check the ground wire for opens or abrasions. Visually inspect wire harness for signs of wear,corrosion and corrosion. Corrosion will usually show up as a green color around the wire conectors. Due to coper oxide deposits from electrolosis. Hope this helps, I really do. Ride on brother!!!!!!!
Mar 29, 2014 | Harley Davidson FLHR - FLHRCI Road king...
The Ground wire is hooked up right but the red light wont go off and stay green so the amp will work. It is very frusterating all the cables are the right size its is a 1000 watt amp. I have two 500 watt...
Sounds to me like the amp is going into protection mode. Try placing one sub on the amp with very little gain. One of the biggest reason why this happens is because the subwoofers are wired wrong. What is the brand and model number for your amp?
Apr 14, 2011 | Car Audio & Video
Hey i dont know to much about amps, but me and my friend (he knows a decent amount about amps) would plug the power into the amp and the green light would come on. Though when we plug it into the subs, the...
Are you connecting positive to positive and negative to negative from the sub to the amp? If so, try positive to positve (+) in the far left channel and then the negative to negative (-) on the far left channel to. If no luck do the same in the other channel with one sub at a time. Try one sub at a time, Dont try an connect 2 or more subs to one channel as this would cause the amp to go into protect mode (red light you describe). Usually the positive wire has either a line down the wire, writting on it or has a red seperate wire with it when wire end stripped to connect it. Hope this helps and please rate...
Mar 11, 2011 | Bazooka EL1500 Car Audio Amplifier
Everything did work but kept blowin fuses by the battery. Now a red light stays on, on the amp & the blue/green power lights dont *** on. What should i do?
Check all of your power connections, your speaker connections and battery connections. if all are good and clean (no shorts/wires touching) then try unhooking your speakers and see if the lights come back, if that helps then you have problems with your speakers, if not then amp is bad. I hope this helps ya.
Randy
Feb 17, 2011 | Phoenix Gold Titanium 800.1 Car Audio...
Wondering if non soldered terminals will cause subwoofers to cut in and out...amplifier turns on and stays lit green but subs cut in and out...have had amp and subs switched over from another vehicle in...
You're right; The clip-type or pinch-terminals could have just enough wiggle room to break connection when the box vibrates....causing the In & Out scenario.
You mentioned that the set (amp & subs) were mated in another vehicle, so there's little doubt that the subs are under-rated for the amp, right?
No chance that the sub-level adjustment was cranked up during the move, causing the aging subs to wash out...and you triple-checked the polarities,right?
Mar 28, 2010 | Sony TA-FE370 2-Channel Amplifier
Protection light stays on
not unhook the amp completely let it sit for 15 minutes it should reset it self and rehook the amp starting with ground rca and remote than the power last it should be back to normal
Apr 20, 2009 | Directed 2400d Car Audio Amplifier
Amplifier Problem
never ask geeksquad about amps lol check your ground wire connection and push on sub do you feel scratching if so its blown sub also never turn an amp up all the way it starts pushin dc voltage witch a 200 watt amp can blow a 800 watt sub dc voltage is not good for subs also up all the way can burn out the internal battery in the amp lets hope thats not it just make sure ground is good protection light means that the amp has power but a connection is not bien made sum where to complete the circut
Apr 12, 2009 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Subs sound terrible (Ive tried so many things)
NO it won't be your battery. Sounds more like your deck.
Jan 22, 2009 | Jl Audio 12W3 Car Subwoofer
KICKER KX350.4 sound fading in and out
Does the amp continue to go into protection if you disconnect the speaker wires from the speaker terminals?
Apr 14, 2008 | Kicker 04KX350.4 Car Audio Amplifier
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
59 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
