PUT NEW TONER IN AND MESSAGE STILL COMES UP TONER NOT SET INSERT NEW TONER
  • 615 Answers
The ink cartage not set all the way or the door not securely closed, or the unit not clean and has a dry ink inside...use bot ways to clean it the first by cleaning the heads by the software using the manual and the second by hand using a clean cloth or cotton swaps and clean good the inside housing...then run alignment...let me know if that work and please remember to rate my service so I am able to continue provide quality service and improve on it with your help. God bless
Posted on Sep 24, 2009
  • Norman Al-Anbar Sep 24, 2009
    help. God bless
Oki b6300 set drum toner cartridge, I replace the toner twice put it still give this message, and the new toner if i put it in anthor printer this message apper eventhough the toner is new and I tried two...
Press the Menu button
GO to "Admin Menu"
Select "System Settings"
Select "Drum/Toner Life"
Choose "Continue Print"
(press Feed/Select - which places a * next to the field)
press the Menu button again to exit
Feb 24, 2014 | Office Equipment & Supplies
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Put in new toner into KonicaMinoltaBizhub200,says exchange toner
Machine is still saying to exchange toner because toner is not feeding into the machine. to supply the toner always do this, 1-insert the new toner bottle in the toner section and close the cover. 2-Press "Utility/Counter" Button. 3-click on "USER CHOICE" or "USER SETTING" 4-click on "Toner Supply" 5-Toner bottle will start moving and hence the error message will not appear again.
Oct 27, 2009 | Minolta bizhub 200 All-In-One Printer
Insert toner card
I think you mean insert the toner cart, meaning just that, if you just put a new one in is it OEM, and if it is try gently shaking it to unclump the toner in it. -Carl
Jul 07, 2009 | Ricoh FAX2900L Plain Paper Laser
Toner is not set Insert toner. Toner is set.
toner is like the catridge.. i think yu ve an laser printr.. yur toner is removed or else loose.. yu shd fix tat problm... by checkin yur toner.
Jul 06, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE DRUM MESSAGE COMES ON. PUT IN NEW TONER, TONER END OF LIFE MESSAGE COMES ON.
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Jun 15, 2009 | Brother DCP-7020 All-In-One Laser Printer
After replacing the toner cartaridge, the error light comes on. In the little box, it says toner is not set. Insert toner. I have readjusted it several times. It seems to be set solidly. The problem...
You have to:
1. take paper out.
2. remove the toner
3. place the toner back
4. printer will "initialize" itself.
5. put the paper back.
Totally crazy!!!
Jun 30, 2008 | Office Equipment & Supplies
Toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Nov 06, 2007 | Canon imageRUNNER 400S Copier
Mfc-7220 replaced starter cartridge, new Brother one gives error no cartridge
there is a new toner detect sensor left front upper inside of printer, when a new toner is put in reset lever on cart hits sensor then fall back to front of cart, remove gear asst and put lever in new position, 3/4 the way back. reinsert toner into drum and insert.
Nov 03, 2007 | Brother MFC-7220 All-In-One Laser Printer
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
