Question about Flat Panel Televisions
Drooping tv wall mount
This mount will not allow us to properly install the 32" 29lb tv
not enough tension to tighten it up for the weight of the tv
tv wants to droop forward
SOURCE: TV wall mount screws for Dynex 32" TV, which size?
Orchard supply.....Metric Cap Screw size:
M6-1.0 x 12MM
They come 2 to a package for about $1.39
Posted on Jan 30, 2011
0 characters
1 Points
Omnimount tv mount strong enough to hold?
Even though there is a significant weight difference, your Omnimount might not be adaptable but I advise working carefully if you try it to avoid an expensive crash.
Nov 09, 2013 | OmniMount FP-CL Medium Cantilever Mount...
How much does this TV weigh? Is it considered a 32" when mounting on wall or do you considered the entire diagonal at 38"?
The TDA-03211c weighs 39.5 pounds; however, I'm not sure if that is with or without the base. The shipping weight of the TV is 50.3 pounds. Most wall mounts use the standard screen diagonal measurement to determine what size TV it will support. So the 32" is sufficient information for choosing a wall mount.
I hope this helps.
Nov 28, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
What is the weight of model TX-42F430S Television. I am mounting it on the wall. Thank You!
I found 2 different sources online that list the weight as either 61.1 lbs or 68.1 lbs. I think the 61.1 is more accurate for the bare TV without the stand or anything attached. But keep in mind that when mounting a flat panel TV to a wall, you should secure it with hardware rated for much higher weight tolerances. Many mounting brackets for TVs of this size are rated for 150 - 200 lbs, and for good reason. Consider a situation where someone trips and catches his balance on the wall-mounted TV. The TV is already putting 61 lbs of pressure on the bracket, so any force from any other contact is added to that. It doesn't take much to add up to 100 lbs or more. If the mount breaks free from the wall, you'll have damage to the TV, the wall, the mount, and any furniture or flooring beneath the TV, so the best advice is to mount it as if it weighed about 150 lbs. The 7 lbs +/- difference in reported weights won't matter at all.
Jan 25, 2011 | Westinghouse Flat Panel Televisions
How do I remove the base from the TV to mount it on the wall?
See page 9 of the user manual, you need to remove 4 base mounting screws.
You can download the user manual from Sanyo website:
Please leave rating if it helps.
Jan 09, 2011 | Sanyo DP50747 50 in. Plasma TV
How much does the Maxent MX-50X5 Tv Weigh? I need to put it on the wall but everyone asks how much it weighs so i can get the right mount.
Weight:106.5 lbs according to i did simple websearch (boolian, example Maxent MX-50X5 Television+ weight) and the search came up with that. you may need to convert it to metric if your from outside usa. i would go with a bracket with a higher gross weight, and be sure to mount it where there are wall studs, the bracket will come out if not properly mounted and down will come your tv..
Best of luck
Oct 17, 2010 | Maxent MX-50X5 Television
I need to know the size of screws i neddto wall mount my tv
First you need a tv wall bracket made for that tv's weight and size to have a safe tv on your wall. The tv must be secured properly or it might fall. So the screws would come with this mounting kit and if they didn't I would fined out were they are. You must mount to a strong structure, like a stud in the wall or a metal frame built for it. The screws that I would use if might mounting kit did not have them would be as big as they would fit in the mounting bracket holes and that all the mounting holes wear being used and long enough to not be pulled out and in the stud about 3/4 of the way through the stud. They would be a good metal screw with a washer and the right threads for what ever material you are mounting it to. Thanks
Oct 05, 2010 | Flat Panel Televisions
How do I wall mount the 65" TV. There are no instructions in the manual provided with the TV
You can buy a universal wall mount the will fit on that 65" plasma that comes with all necesary hardware and instructions to mount the TV to the wall. Now that 65" tv is really heavy so it needs good anchors to support the weight of the display.
Jan 02, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Can I use any universal wall mount for my LG
Just check the weight and size restriction on the wall mount. As long as the weight and size specs of the TV fall within those allotted by the wall mount, you should be fine.
Nov 13, 2009 | LG 50PC5DC 50 in. Plasma HDTV
Samsung tv wall mounting
For a true flush mount installation, you will need to recess your connections (i.e. power, HDMI, S-Vid, etc). Most tvs have the connections coming out of the bottom to allow flush mounting.
If your wall is not drywall, or you really don't want to bother with the expense of recessing your outlets and cable connections, just get a swivel arm mount. It will allow the TV to sit a bit further from the wall and still look ok.
Go to for great deals on mounts. I have 3 of them in my house and they are excellent quality.
May 22, 2009 | Samsung LN46A650 46 in. LCD HDTV
Flat Panel Televisions Logo
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
