Question about Viscom V2 Premier 17'' LCD Computer Package W/$50 Rebate (V34372) PC Desktop
Visco televison no picture or sound - Viscom V2 Premier 17'' LCD Computer Package W/$50 Rebate (V34372) PC Desktop
Visco vsc32v1 ,I turn power on but no sound or picture.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 05, 2015 | Televison & Video
Where do i find a remote controll for visco model vsc-32v1?
Visco is a value brand, originally built by mitsubishi/nec. When the major companies supercede their sets with newer models, they strip down the original design and put them up for contract to be marketed by third parties. Same basic guts as the polaroid sets. Directv lists a remote code, 10810, for these sets, so you should be able to buy a universal remote that will work this set. It would be much cheaper than trying to find an original remote.
Nov 29, 2014 | Televison & Video
My lcd element FLX-3711B dont turn on.. I plug the cord cable and only flashing front red light? Whats the problem?
The Element FLX-3711b TV is the same unit as several model of Polaroid and Visco TVs. They are all made by the same company just labeled fr different brands. The flashing power light is a very common problem and is caused by a failure of the power supply board. The capacitors on the board short out and this causes the board to not power up correctly. Here is a link to a repair guide for the Visco TV that is the same as the Element FLX-3711B so the information will be the same for both units. The repair guide shows the parts that will need to be replaced on the power supply board to rebuild it.
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
I hope this helps you out.
BuddyMc
Jul 10, 2012 | Televison & Video
Screen isn't blue when you turn on its white
The most common cause of white screen and no picture problems on this unit is a failure of the power supply board. Here is a repair guide with full dis-assembly and repair instructions that should be able to get you back going again. This guide is for the Visco TVs but the boards are the same as the Polaroid model
I hope this helps, if so please rate my solution.
BuddyMc
Dec 25, 2011 | Polaroid FLM-323B Television
I have a Visco 32"
Have you used this TV before or have you move it to a different source? I sounds as if it is trying to scan for channels as it states in the manual. If you have the manual check out page 14 Memorizing the Channels. If you don't then download it from: http://www.retrevo.com/support/Insignia-IS-LCDTV32-TVs-manual/id/8223ag521/t/2/
Good luck
Tom
Aug 05, 2011 | Insignia IS-LCDTV32 32 in. Television
We have a 32" Visco LCD TV (about 5 yrs old), we have sound but have no picture. I tried the service desk but can no longer find Visco help anywhere. A company that sells parts directed me to your web...
I can only sggest you go back to your supplier to seek advice. They should hopefully know where a company that supports this set will be.
Sorry.
Oct 22, 2010 | Televison & Video
I have a VISCO VSC-32V1 ser # 64232104307 that has no picture< just a blue screen. VISCOs phone number is disconnected. Is this HDTV worth repairing? If worth repairing are there parts available?
These sets are identical to polaroids, which are terrible. I would not recommend fixing it. They are poorly designed. Parts are hard to come by. It sounds like a video board problem.
Jul 25, 2010 | Televison & Video
TV won't turn on
these tvs are no good its was waste of my money but thats what u get when u try and go the cheap way out.
May 12, 2008 | Insignia IS-LCDTV32 32 in. Television
Computers & Internet Logo
14 people viewed this question
Top Viscom Computers & Internet Experts
JonSnell Electronic
JonSnell Electronic
Are you a Viscom Computer and Internet Expert? Answer questions, earn points and help others
