Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
WHIRLPOOL MODELED5VHGXML10 HAS WATER RUNNING FROM UNDERNEATH
THE PAN IS FULL OF WATER AND I CAN'T FIND A WAY TO REMOVE IT.
    Sergeant:
    Champion:
  • 255 Answers
Is it over flowing on floor ? the pan is the one under fridge on the out side ? it should be full but not over flowing.
find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
Posted on Sep 24, 2009
Why does kenmore side by side model 596.50004100 leak water from bottom?
1. there is a condensation pan under refrigerators, pull front bottom grill off & you should see pan. if pan is full it will overflow, pull forward to remove & empty. also check to see if something spilled in bottom of fridge & is running into drain hole into pan. most of the time condensation is so slow that it will evaporate before the pan fills up, but I've had them fill up on me in the past, not too often though.
2. if fridge is equipped with ice maker & clod water dispenser, connections on bottom back side could be leaking ( not likely, unless they have been disturbed).
there is not much else that it could be unless it is not the fridge & is coming from some where else & running under the fridge.
Oct 09, 2014 | Refrigerators
Removing the water pan underneath the fridge.
You would hope it was accessible from the front, but no. You probably have to roll the fridge out, not breaking the water line, and get to the pan. You may have to remove the paperboard rear cover, usually takes a 1/4": nut driver. Vacuum out all the dust while you're back there.
Nov 26, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side full drip pan
The condenser fan should be running whenever the compresser is running. With all of that condensate, I would look at your door gaskets. If they are leaking and you are in a high humidity area you will produce more condensate than what the pan can Handel. Then again. If the compresser is running the heat from the discharge line should evaporate the water with ease. I would look at the seals possibly leaking and ignore the full drain pan.
Sep 08, 2012 | Whirlpool Refrigerators
Whirlpool S200 RBB32 water leaking from underneath?
Have you checked the drip pan under the fridge it could be full,or the drain line may be leaking.
Aug 13, 2012 | Whirlpool Refrigerators
How do I remove the drip pan from under the freezer? It's full and leaking onto the floor?
There should be a decorative kick panel underneath that will snap out revealing the drip pan which will then slide forward and out to pour the water off.
Nov 25, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Evaporator pan overflows. Outside of refrigerator gets hot periodically around the door.
Warm sides-
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
evaporator pan-
When the water filter is full some are designed for the water to go to the evaporator pan. Check to see if the filter is stopped up.
Oct 11, 2010 | Refrigerators
Water freezing in bottom of freezer. freezer is 10 years old.
The defrost drain outlet is stopped up and freezing over.
Remove the bottom basket.
Turn the freezer off.
Look in the center of the freezer just below the cooling coils in the bottom of the freezer.
You will see a water drain trough.
It will be full of ice.
Use a hair dryer to thaw the ice and remove it.
The drain will become exposed.
It must be thawed also,so that you can pour water through it and the water goes all the way to the drain pan underneath.
Sep 18, 2010 | Whirlpool Freezers
Whirlpool 25.6 cu. ft. side by side with overflow pan underneath spilling over.
make sure that condensor fan motor which evaporates that water is running..
May 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water in box waqter keeps accumulating on shelves iveg bins andunder bins
When the freezer goes through the defrost cycle, the water collects in the defrost drain pan and drains into a pan underneath the unit where it evaporates over time. If the defrost drain pan is clogged, the water will fill the pan where it will freeze. Once the pan is full of ice, the water from the defrost cycle will run over the pan and down into the fresh food section. This will require that the drain pan be clean of the ice and the drain tube cleared of ice and debris.
Hope this helps.
Aug 07, 2009 | Whirlpool Refrigerators
Water pan inder freezer is full & leaking water
it may be that your defrost drain hole is blocked at the back. check it out but runnin a flexi band down it. if its the freezer drain hole you will need to do a full defrost to unblock ice.
Mar 16, 2009 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
96 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
