Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
My a516 was run over by a power seat. Now
My a516 was run over by a power seat track in a car. Now everything works except the lcd screen inside. It has a rather psychadelic look to it. Can I replace this screen myself?
Lcd screen doesnt work
check lcd connection & clean.if ok flash software.
May 30, 2012 | Canon PowerShot SX20 IS Digital Camera
My laptop screen is bright. Brightness control works but no picture. The picture is ok on external monitor. Sometimes a faint and incomplete picture appears on startup but disappears after a few seconds....
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Aug 25, 2010 | Compaq Presario 700 470024-192 Notebook
Power seats wont move forward
it souns like the switch on the seat has stopped working or the motor itself has gone bad I would check the switch first
Aug 01, 2010 | 2006 Nissan Murano
Everything works on the power seats except unable to move seats forward and backward
There are usually 3 motors for power seats, 1 to tilt the seat, 1 to raise and lower the seat, and 1 to move the seat back and forth. I would think that motor is bad. Check for any obstuctions to the seat track.
May 06, 2010 | 2005 Chevrolet Trailblazer Ext
Screen is not working
It is a posible issue with the hardware the LCD or the power connector of LCD to the body. Another thing there might be a short circuit inside.
You can perform this T/S:
1. remove all accesories connected including battery.
2. press the power button or switch to on for 1 minute to release all the electrical current inside.
3. turn on the camera check if it will work.
If the problem persist then it is a hardware issue and LCD needs to be replaced.
Apr 06, 2010 | Sony Handycam DCR-TRV9 Mini DV Digital...
The front LCD clock, and/or message icon on SamsungSGH-a516
Hold the side up or down button for more than 2 seconds. Clock will appear briefly.
Aug 18, 2009 | Samsung Cell Phones
I have a samsung a516 cell phone and everything works on it except the screen is blank, so i can't text or see whose calling, the phone needed charging so i did that and still nothing on screen when...
Blank screen. Is there any instance that the phone was dropped or exposed to any form of liquid? If not I think there might be a problem with the phone's lcd that needs to be replaced.
Jul 05, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Scrambled LCD tv picture
I would think its a T-con bard fault its the main board for the screen over time they ware out from heat. this control the picture for the screen. they can go in many ways, black screen mixed or shadows even star screen and scramble type screen. and white lines and even half working only.
Jun 07, 2017 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Power seat moves on 1 side only
Look very careful inside the track and see if anything is interfering with the gear mechanism. It doesn't take much to lodge in there and cause the gear to lock up. If everything is clear, there is a cable that attaches the motor to the gear, that cable may be stretched or broken.
Bret
RepairPal.com
Oct 31, 2008 | 2002 Volvo S60
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
44 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
