Question about Lands Phones
Phone does not work
No link to base
  • 8 more comments
  • Anonymous Jan 05, 2008
    portable handset don't work
  • Career Jan 22, 2008
    Cannot make calls. Tells me there is no link to base, however all lines and power cords are connected and handset is fully charged!!
  • sferreira59 Feb 07, 2008
    Phone worked just fine on moving day. Moved phone to new location, plugged it in and handset now says "no link to base." Anyone have a solution?
  • fyrlys Jun 03, 2008
    Phone has been working fine. Just got a call on the phone. Tried to use few minutes later, and main base says "green" (phone in use) and extensions all say "no link to base". My ground line is fine and has a dial tone. I can also use dial-up on the internet. Just can't use the Panasonic phones.
  • Jazzetta Jun 08, 2008
    phone is charged but says no link to base.  Doesn't matter which phone or base, message stays the same.
  • rnlindaa Aug 19, 2008
    No link to base.
  • Anonymous Aug 22, 2008
    Same here.
  • Anonymous Oct 14, 2008
    no link to base
  • Anonymous Jan 19, 2009
    no link to base
  • fishdrzig Feb 03, 2009
    No link to base. Reconnect AC adaptor.
I had exactly the same problem. I tried re-registering the handset several times with no change. In desperation, I took the battery out of the handset for a minute or so and unplugged the transformer from the wall. I reinstalled the battery and plugged the transformer back in and voila! The phone now works! No guarantees that it will work for everyone, but it worked for me.
Posted on Aug 10, 2008
Thanks be to God!! I would like to express my appreciation for forms like this. I have a Panasonic KX-TG5433 with three hadsets that lost their links to the base. I tried everthing, including removal of batteries, disconneted and relocating the base; however, after reviewing a suggestion of removing batteries and unplugging base for at least 3 minutes....IT WORKED. It is about 1:40 am and when my wife awakes in the morning, she will know that I am still the man!!!
Deacon WRC
Posted on Sep 22, 2009
    Problem Solver:
  • 7 Answers
I had the "No Link" problem and removing the battery and unplugging worked for me!
Thank you!!!!
Posted on Feb 11, 2010
Panasonic:
Model KX-TG2217S
Phone was working fine. Got static on line so decided to try another phone outlet. Got "No link to base - Place on cradle and try again". Now it does not work in the original outlet as well.
Checked phone line to outlet - swapped with a new one and no difference. Removed battey and tried and same thing.
Thx for your help.
Azim.
Posted on Sep 25, 2008
We have samsung kx tg 5576 phone,its showing no link to base,i tried unplugging ac adapter and batteries ,it still shows the same,an u help me please.....
Posted on Jul 06, 2011
Phone says no link to base phone stop working
Try unplugging the base unit and plugging it back in again. This is not guaranteed to help but has worked in the past.
Feb 28, 2010 | Panasonic Lands Phones
No link t move closer to base try again base
this depends on what phone you have. most pjones when you open the back of the battery cover, their is a connect button really small. look around the base for a connect button and press the base connect button first, then the phone. after abit they should connect to each other. plaese let me know if this does not work
Feb 23, 2010 | Lands Phones
Phone says OUT OF RANGE while on the base and won't work.
The handset has lost the link with the base. This link codes the handset to the base with a unique security code so others with the same phone cannot use your phone line.
If you changed the battery, try disconnecting the base telephone line and ac adapter for a while (1/2 hour or so if possible).
Remove the battery from the handset as well.
After 1/2 hour, install the battery in the handset, connect the telephone line and ac adapter to the base. Place the handset in the charging base and the link should be established. If not, the phone is defective.
joequevedo@charter.net
May 07, 2009 | GE 27992GE5 Cordless Phone
"no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
May 01, 2009 | Lands Phones
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
GE 900mhz model 26936GE2-C
HI NEED HELP MY PHONE IS SAY NO LINK TO BASE
May 20, 2008 | Lands Phones
Its saying no link to base,move closer to base, try again but the phone is right beside the base what do i need to do?
I also have no link to base message but only on one of my two handsets. One works the other doesn't.
Any suggestions?
Apr 15, 2008 | Lands Phones
No link to base
put the phone in its base and then un unplug the phone for 5 seconds plug it back in and check for a dial tone.
Feb 20, 2008 | Lands Phones
No link to base
The solution works!
Thanks.
Feb 15, 2008 | Panasonic KXTG2344 Cordless Phone
Link to Base
unplug both wires at back of base and replug after about 5 minutes - it should work now
Dec 30, 2007 | Panasonic KX-TG2357 Cordless Phone
Lands Phones Logo
1,107 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
