Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
It is not draining. The sink is full of water on
It is not draining. The sink is full of water on both sides
  • 615 Answers
It is full of hard stuff that does not allow the water to get through...see if you have a small tool under the sink connected to the disposal and put it under the unit and make few turns first to see if anything hard is stuck inside i.e. spoon, fork, etc. and push the red button at the bottom of the unit too to reset it and start it and see if that work, you may need to do it few times...make sure that you have nothing hard inside first that will brake it...let me know if that work and please remember to rate my service so I am able to continue provide quality service and improve on it with your help. God bless
Posted on Sep 24, 2009
    President:
  • 1,564 Answers
If all other drains throughout the home are draining as per normal, than you've got to snake the piping after the disposal unit. You might also want, if you have the type, to remove the lower casing(motor) from the disposal and try to dislodge any food buildup within. It is imperative that someone stands by the operation switch and allows no one to flip the switch. Thank you, Dana
Why does kitchen sink drain water from drain side to garbage disposal side
The two drains are connected, but below the disposal. Likely if it's not draining down, you still have a clog, and the person the "cleared" the drain didn't.
Sep 03, 2014 | Garbage Disposals
When dishwasher is emptying it is backing into sink
there is probably nothing wrong with Dishwasher itself.
Your Sink drain is stopped up or your Garbage disposal is clogged.
usually, dishwasher drain is connected to the Garbage Disposal, but if the dishwasher empties the water into the Garbage disposal, if its clogged then water will come out of the sink. Same if sink is clogged between sink and sewer.
If you fill up your sink and then water drains away, then you know your sink itself is not the problem. If its only the Garbage disposal side that does not drain, its the garbage disposal that is clogged.
Dec 22, 2013 | Dishwashers
Why does my washing machine (located in the laundry room) back up into my kitchen sink
I it hard to believe that a sink full of water will drain "freely" if the washing machine machine water will not. My suspect is that a minor blockage exists in the main sewer drain line-AFTER the point of connection of the washer. A cleanout point probably exists near that point of connection. Please use it to clear the line.
Jan 05, 2012 | Dishwashers
My dishwasher is draining into my sink and filling it up.
House drain must be plugged, other wise water would be going down the drain.
May 19, 2011 | Dishwashers
DISHWAHER WONT COMPLETELY DRAIN ALL THE WATER OUT AFTER WASH CYCLE. JUST CHANGED OUT SINK FROM DOUBLE TO SINGLE.
drain hose is to low to sink connection zip tie side connected to sink up towards bottom of cabinet top so water dosent backflush into dishwasher from sink draining
Jan 27, 2011 | Maytag EPIC MFW9700S Front Load Washer
When my dishwasher drains both sides of sink fill with water...then they both eventually drain back into the dishwasher.
Sounds like your sink drain trap or line is clogged. When the dishwasher drains, the sink drain can't keep up, the water backs up, then backs down the dishwasher drain line into the dishwasher. You may not notice the slow line when you run a little water into the sink, but with the amount of water coming from the dishwasher the problem is worse. You can try taking off the trap under the sink and making sure it's clear. If the problem is farther down the drain line, you can try snaking it yourself, or call a plumber. I don't recommend using Liquid Plumr or Drano because if those don't work, they leave the line full of caustic chemicals for the next person who works on it. That can be dangeerous.
Dec 07, 2010 | Microwave Ovens
Here is an interesting problem. We have a Badger 5 1/2 Hp Garbage disposal hooked up on left side of double sink. The Disposer runs, spins, but will NOT drain.. at all. Left sink with the insinkerator will...
If this connects into a tee between the sinks, usually if the tee is in the middle of sinks, then often there is a divider in the tee to keep water from backing up the other drain. Remove the tee and inspect to be sure it isn't cloggged. Also put a bucket under the outlet. Try running it this way, if you get good flow you know the disposal is working
Aug 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
SMEG DWI612C WON'T PUMP WATER OUT
even if the pump is running does not mean the impeller shaft is turning, You could unplug the machine and disconnect the washer and pull out and drop the hose to see if water will drain when you lower the hose to about 8 inch's does it run out freely? if not check for a plugged water pump or water pump hose if the water flows freely you will need to drain the washer if it's on rollers roll it out side to allow the water to drain out the machine from the porch. while it is draining check the hose that the washer connects to see if you see any plug in the pipe. put the sink drain plugs in and fill half way with water put a bucket under the sink after filling the water to half full pull the stopper out of the sink that connects to the dish washer. Hold your hand on the hole of the connection to the sing watch to see if the drain allows the water to flow. If it flows freely you can assume that the water pump is bad. If thats the case it's best find someone to replace the unit the pump can be replaced but you need tools to do so and you did not state if you had any. thanks for using fix-ya.
Apr 18, 2010 | Smeg 18 in. DWF409WH Slim-Line...
My dishwasher backed up into my kitchen sink , it was about 30 minutes into a 2 hour wash cycle--i drained the diswasher, but 1 inch stayed in it till this morning, the sink drained on its on
It sounds like an issue with the sink drain rather than the dishwasher. Many dishwashers are connected to a double sink, one bay of which contains a garbage disposal. If yours is connected in that configuration, run the disposal to clear any food debris that may still be present while running the HOT water into the disposal.
If you have no disposal or if the dishwasher is connected to the other non-disposal bay, check the sink drain again for proper drainage.
The easiest way to do this is to put a plug in the drain (both sides, one at a time), then fill the sink about half way with luke warm water. Then reach in and pull the plug from each side, watching to see how each side drains, but especially the side with the dishwasher connected. If it's slow draining, focus your efforts on clearing the drain on that particlular side of the sink. Try a plunger first before resorting to other methods to clear the sink. If you plunge the dishwasher side, get underneath the sink and pinch off the discharge line from the dishwasher if possible. A pair of vise grips works well, but don't overtighten them.
Some dishwashers have a soft disposal that can eject enough ground up particles into a sink to cause plugging up over time, especially if the dishwasher empties into the disposal side.
Jan 20, 2010 | Whirlpool 24 in. GU980SCG Built-in...
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Apr 10, 2009 | Advent KRAUS Amber Rectangular Glass...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
1,292 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
