Question about Cameras
Digital camera I can't seem to switch it on even with brand new batteries
  • 9 more comments
  • RobertBr Dec 19, 2007
    Unit powers on on AC power or external battery OK...but picture from the lens is black...otherwise screen works (though menu won't let me change the date/time).
  • Anonymous Feb 13, 2008
    After camera gets turned on, it starts to beep, and then shuts off. Won't stay on.
  • cac1031 Mar 19, 2008
    i put brand new batteries in my camera and I turn it on and it shuts off again saying the battery is low and I have tried several different new batteries and am having the same problem
  • Anonymous Aug 02, 2008
    With new batteries, and the on switch pressed, the green "on" light switches on for a fraction of a second, then nothing else happens. It will not turn on.
  • pl6975 Aug 07, 2008
    I also have the same problem, it keeps telling me to change the batteries but I keep putting new ones in it, won't stay powered on
  • Anonymous Sep 09, 2008
    Same problem - new batteries = not enough power to extend the lens and switch on. Is it possible that the camera needs 7.4Volts (written on the bottom) but only has 4 x 1.5Volt batteries ?!!!
    John H
  • jeanlefur Dec 08, 2008
    My Canon S2IS does not respond to new batteries, Alkaline or NiMHd rechargables. On switching on the immediate response is a directive to change batteries, which is most annoying, to say the least. Can anyone suggest a remedy that does not entail expensive repairs or buying a new camera? Initially the camera has produced some excellent results.
  • horacio230 Dec 09, 2008
    My Powershot A520 keeps turning off even with nre batteries.
  • David Jan 17, 2009
    Same error, new AA batteries of any type won't help. Could it be the little CR1220 date battery?
  • latinawomen Feb 16, 2009
    my camera keep saying low battires I got some new ones and it still says low battires
  • Travelling09 Mar 15, 2009
    I have the same problem with a Canon A540. Was working fine other than giving a low battery warning, then died completely. I've tried several sets of new batteries (rechargeable and non) but still won't give enough power to take a photo. Viewing photos seems OK for now.
There is tiny place with the wrighting of "C1220" - pull it out and put a new bat. all be solved
Posted on Feb 12, 2009
  • 5 Answers
I've now had this happen a couple of times; it seems to get confused. It would *almost always* turn on to play mode and show pictures, but would give a battery error when switched to record. At first, just random on/off & switching modes would eventually bring it back. The last 3 times, it worked directly to turn on to play mode, then hit the SHINY RED BUTTON (movie record), and it would switch to shooting mode and be fine thereafter for a long while. Can't hurt to try.
Posted on Feb 13, 2009
My Samsung WB100 turns off after switch on. Got new batteries and same problem plus 'old' batteries are still good even though camera said they needed replacing after a few days minimal use.
Make sure you are using name brand high quality batteries and not some generic from China. Camera require a great deal of power to boot up.
Jan 25, 2013 | Samsung Wb1000 Digital Camera
Camera always says low battery even when you put in fresh batteries..will not allow me to take any pictures
Hello. Remove the batteries and use the eraser on the end of a common pencil to clean the contacts. Then replace the batteries and turn it on. J.
Jul 10, 2010 | Samsung Digimax A7 Digital Camera
My camera seems to be drawing energy from the batteries even when it is off because when I put brand new betteries in, within 72 hours they appear dead. I have the Canon SX10 IS. The camera is 10 months...
I have had the same issue. However, it is not draining the batteries, it is telling you the batteries are low even though they are not.
Sorry I don't have an answer though. I have checked batteries after the camera told me they were low/unusable and found them to be fine.
Oct 12, 2009 | Canon PowerShot SX100 IS Digital Camera
No lights no power
Make sure to try a set of good quality batteries. I had the same problem with 6 sets of batteries. I thought my camera was broken. I was using generic alkaline batteries. They checked okay voltage wise but they didn't have the milliamps necessary to drive the camera. I switched to a good name brand and the camera works like a new one.
Jan 01, 2009 | Samsung S860 Digital Camera
Camera immediate shuts off after turning it on
try using lithium or nimh rechargeable batteries. I had the same problem and switched out the batteries and put in eveready nimh batteries and it works fine now. Guess the old cheap ones weren't doing the job. And they were brand new batteries.
Oct 12, 2008 | Nikon Coolpix L11 Digital Camera
Disney Pix Micro Digital - stopped working after 10 minutes
The type or memory in the camera requires a charge in order to store data. So if you have any pictures on the camera it will constantly be pulling a charge from the battery until the battery is completely drained. If you have this problem even with a brand new battery it's possible that the memory may be corrupt and needs to be cleared. To do this just remove the battery and press both buttons several times each to make sure that the camera is completely discharged, replace the battery with a brand new battery and try again. If that fails I'd get in touch with customer service for a replacement.
May 18, 2008 | Disney Pix Micro Digital Camera
Kodak easy share c875
When you say you've tried every different kind of battery, did that include Lithium batts?
Lithiums are the only battery that ALL Kodak cameras seem to be happy to run on.
They have huge problems with alkaline batts, even brand new ones.
Hope this helps.
Dec 29, 2007 | Kodak EasyShare C875 Digital Camera
Fujifilm finepix A345 4.1
an intermittant fault with the switch seems likely Check Fuji support, but if they want to make a charge it may be worth buying the next camera
Sep 02, 2007 | Fuji FinePix A345 Digital Camera
Not staying started
It's the type of battery you are using. Use a rechargable battery or a long-life disposable rated for digital cameras. Regular (cheap) AA batteries don't have enough power to run this type of device - even if they are brand new. Save the cheap batteries for your wall clock.
Jun 05, 2007 | Vivitar DVR310 Digital Camera
Cameras Logo
158 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
