Question about Intel D101GGC Motherboard
My pc is stuck
I have a major problem in my pc configuration is Intel Pentium 4 3.0ghz+Intel D101ggc mother board+1gb ddr ram(400mhz)+Nvidia 8600GT graphics card. my pc is runnig good,even aero theme is running,suddenly it hangs up.any device did not work that time.even [ALT+CTRL+del] or even Mouse courser does not work.Totally freeze. This problem is very frustrating.what can i do?Please help me out.
  • 748 Answers
Hello
This kind of screen lock is usually caused by heat. Some component is heating up past it's tolerance. The problem is which one? Are all your fans working? There should be 1 or 2 fans in the power supply, 1 or 2 fans in the case, 1 fan directly mounted on the CPU and 1 or 2 fans for the Video chip. If all these are working then I would do one of the following: if you have the capability, put a scope on one of the cpu data lines. You should see a constant flow of data - even after another chip freezes the system. If you can't do this then just sub out the CPU. Don't forget the heat grease on the replacement CPU. If this doesn't help then you'll need a reputable repair person or check out my website: www.micromendllc.com
Posted on Sep 24, 2009
Emachines t3516a memory upgrade
The eMachines T3516 uses an Intel D101GGC motherboard,
http://www.ascendtech.us/intel-d101ggc-lga775-800fsb-motherboard_i_mb4intd101ggc.aspx
Two Ram Memory slots.
Maximum Amount for EACH ram memory slot is 1GB.
Maximum TOTAL Amount for the motherboard is 2GB.
Ram Memory used is DDR Sdram at 333MegaHertz, or 400MHz.
That is PC-2700 and PC-3200 respectively.
Uses Non-ECC, low density, Unbuffered, CAS Latency of 2.5, and 2.5 Volt.
Regards,
joecoolvette
Oct 01, 2012 | E-Machines T5082 PC Desktop
Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
1.may be the ram is damage
2.your motherboard is not supporting 333mhz bus support
try to find 400mhz ram instead of 333mhz
Feb 27, 2010 | Intel D101GGC Motherboard
I want some information about Nvidia GeForce 9400 GT 1GB DDR 2
If you are using Dual Core the mother board you are using may have PCI Express Slot. So that you may install Graphics card. Only for particular lower end mother board doesn't have this feature. Any way tell me your motherboard make and model no. e.g., Intel DG31PR, 945GNT, DG41TY etc.,
Oct 04, 2009 | Computers & Internet
Vista compatiable
intel doesnt list any vista drivers for that motherboard on there site so you might run into problems with the intergraded devices such as the ethernet,audio,chipset, & any intergraded video
You might be able to use the xp drivers but if theres problems it wouldnt be supported by intel
Nov 26, 2008 | Intel D101GGC Motherboard
Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
Sep 18, 2008 | Intel D101GGC Motherboard
Is there any problem in using a 1GB DDR with 400MHz speed in Intel D845GVSR board?
Since Intel says that this board will support DDR with 200/266/333 MHz speeds only.There should not be problem with your board more so that it works fine.
Jul 25, 2008 | Intel D845GVSR Motherboard
Intel D101GGC Motherboard PCI Express compatibility issues........
i'm using NVIDIA GEFORCE 8600 GT on my d101ggc board and its working fine
Jun 30, 2008 | Intel D101GGC Motherboard
Regarding Upgradation of Rams in My mother board
Please don't post your question twice, I've already answered your other post of this problem
May 21, 2008 | Intel D845GVSR Motherboard
Intel D101GGC Motherboard Logo
96 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
