Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Bake oven element blew
The bake element in the bottom of the oven blew put a big hole in the element. I replaced the element and now the oven will not heat up. Could it be the thermostat or a fuse if it is a fuse where would it be located.
Thanks
  • Anonymous Mar 25, 2014
    de longhi D906 G11
  • 26 Answers
Could be the oven selector switch or the thermostat that failed form thhe element shorting out. You will have to have a ohm meter to check these
Posted on Jan 09, 2008
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
I have a Maytag electric oven model MER5552BAW. Bottom bake element blew out. I replaced the element & now oven will not heat at all. Going nuts!
Go to youtube and type in your model number and ask for repair videos:
https://www.youtube.com/results?search_query=troubleshoot+Maytag+electric+oven+model+MER5552BAW
Feb 20, 2015 | Maytag Kitchen Ranges
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
After putting my 10 yr. old Whirlpool Model RBD276PD double ovens thru the self cleaning cycle the bake and broiler elements in the bottom unit stopped heating. All the controls on the panel work and the...
This sounds like it blew the thermostat on the back of the lower oven. They are inexpensive and easy to replace. You will need to uninstall the unit and remove the back panel to acess. Check it for continuity if none replace. This is a fairly common failure due to the heat of the self cleaning. Here is a link to your part and diagrams are also available there AP3055316
Sep 28, 2010 | Ovens
Oven doesn't work after replacing the bottom (baking) element
Will the clock control accept the bake and temperature request?
If so,
You will need to remove the rear panel of the range and test the bake element leads for 220 volts when the oven control is set to bake and is turned on.
Mar 08, 2009 | Magic Chef CER3725AA Electric Kitchen...
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Mar 07, 2009 | Thermador C302U Electric Double Oven
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
May 28, 2008 | Thermador SC272T Electric Double Oven
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
277 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
