Question about BenQ FP731 17" LCD Monitor
The screen will not start up. It looks like there is a very faded picture but then it will dissapear alltogether. When I hooked up a different monitor to the pc it works fine.
  • 748 Answers
Hello
The lamp or the associated inverter circuitry has failed. You'll need a reputable repair person or check out my website: www.micromendllc.com
Posted on Sep 24, 2009
Tv has red screen and no sound
how are you hooked up? sometimes i get weird colored screens when people use the component cables (red, green, blue, red and white) to hook up but get one in the wrong spot or not in all the way.
uh... if this isn't helpfull try using a different input alltogether. like, if your using video 1 put it in video 2 or if your using hdmi try just using the SD composite (yellow, red and white)
eh, good luck
Nov 18, 2013 | Hitachi Televison & Video
Comes on, but no picture, seems like its stuck in sleep mode
Perhaps the problem lies not with the computer but with the monitor. Is the boot up screen showing like "Windows is starting up..." or do you simply get no image whatsoever? If your screen is blanked out alltogether the monitor may not be connected properly or may not even be functioning at all. Try looking to see if it's connected properly and seeing if it's even getting power... Otherwise I'd replace the monitor.
Mar 22, 2010 | E-Machines (T2824) PC Desktop
Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 27, 2009 | Westinghouse SK-26H240S Television
Handmade guitar amp, when i plugin the guitar i start playing, but then signal gets lost, the sound dissapears, and then it appears again, and after minute or two it dissapears. i've tried to put full...
have you got valves fitted to the amp as they can cause fading if old >damaged >not fittted properly also check the speaker connects and try playing half volume the output should be steady.. you say its handmade if you made it pull out the amp board and check your soldering joints look to see fi there is any that need resoldering as they may be getting hot and causing a resistor to fade..
Aug 02, 2009 | Orange Crush 30R Reverb Guitar Amplifier
Same issue: PICTURE IS HALF THERE- WHAT TO REPLACE?
Any takers for a Class Action Law Suit against LG and report to Consumer Affairs?
Jun 30, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
No images but records sound
To start ensure that you removed the cover from the lens.
Also remove battery and put it back in place to reset the camcorder.
If you get only sound on playback, connect the camera to a computer or TV, or play the tape on a different camera. If you get picture in there, then the camcorder is recording, but the video playback does not work because of a faulty LCD display.
If when you play back the movie on a different camera, or using the compute you still get no picture then the camcorder is faulty.
Faults that can cause black screen can be:
Lens problem. Faulty CCD sensor. Faulty controller board.
All this faults are not easy to diagnose and fix, if there is a fault , then it is better to take the camera to a repair shop.
Jun 17, 2009 | Quasar VM-L153 VHS-C Camcorder
Problem with Samsung SyncMaster 226BW
Click the top button on the side of the monitor to open the monitor's settings. In the "Picture" Settings, scroll down to "MagicBright" and open those settings. Chances are you have it set to "Dynamic Contrast". Switch that up to any of the other settings and then it won't try to adjust the gamma based on what is on the screen.
Hope this helps, I struggled with the same problem for quite a while until I found this setting.
Feb 19, 2009 | Samsung 226BW Monitor
The picture on my lcd tv started to fade and eventually dissapear - now the picture has completely gone and i am left with only sound
the caps have blown on the tv there are 4 of them that control the picture. a repair man will have to fix it cost about 400.00
Aug 27, 2008 | Televison & Video
Picture display
Is the picture getting smaller - then expands?
May 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
BenQ FP731 17" LCD Monitor Logo
613 people viewed this question
Top BenQ Computers & Internet Experts
Tony
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
