Question about Sharp AQUOS LC-40C32U 32 in. LCD TV
Picture goes out right after turning on, have to
Picture goes black turning on and off fixes it but seems to be getting worse when I first turn it on have picture for a couple of seconds and goes out turn tv on and off until it works?
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Posted on Dec 15, 2009
  • Sharp Master
  • 8,457 Answers
Ur power inverter board is dead.
U need a new one.
Posted on Sep 24, 2009
Sometimes when we turn the tv on it will power up but no picture
make sure cables are right because one could be loose or in wrong place
May 27, 2012 | LG 37LC7D 37 in. LCD HDTV
When turned on picture is very wavy (can't tell what you are even watching). After a time it becomes clearer until picture eventually returns. Recently, picture is wavy, mores on top, and has a slight...
The problem is from the lamp of the television, it seems to be having some faults, it is gradually getting damaged.
It will start by being wavy until it goes completely blank.
Some lamps go for about $125 or more. Some go for $200.
Take care and Good luck
Oct 23, 2010 | Televison & Video
No picture
hello
Seems to me that your power supply has weak 330 or 470 Mfd 200 volt capacitors.
Use computer grade Caps
I would have them changed first.
Thanks Guy9
May 07, 2008 | LG 42LB1DRA 42 in. LCD Television
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Line through the middle
socer, solder connections on the vertical output IC are broken, board has to be taken out and re-solderering the pins on the vertical IC will fix it easy job for a tv tech, good luck, BMW Rider
Jan 03, 2008 | Proscan PS36123 TV
Rca p52937sg
Hi, your vertical section is beginning to fail, from your description you have a few electrolytic capacitors that are beginning to go bad, the correct term is they are "leaky", the set can be fixed easily by a tech, not so easy for a layperson because you don`t have the service manual or a capacitor analyzer. NOT an expensive fix, tech will have to remove board, unsolder some caps, check them and replace the bad ones, do a little touch up solder work and set is good as new, any questions? feel free to ask away, if not Happy Holidays, BMW Rider
Dec 08, 2007 | RCA P52937 52" Rear Projection Television
36" CRT Toshiba has that vertical issue mentioned on here a bit
Your problem is most likely caused by a cold solder joint in the vertical circuit. Normally this is easy to find and correct. The problem will only get worse over time, but not likely for more damage to occur.
Sep 17, 2006 | Toshiba 36A41 36" TV
Sharp AQUOS LC-40C32U 32 in. LCD TV Logo
956 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
