Question about Sony STR-DG800 Receiver
No sound through speakers from Sony STR-DG800
I am attempting to complete hookup of my Sony STR-DG800. Unfortunately, I am only getting audio through my TV speakers.
I have connected two good-quality speakers to the receiver as Front A and Front B. I do not plan to use surround sound.
I have connected the system using 3 HDMI cables:
1) Digital cable box to receiver via TV/SAT input;
2) Sony Playstation/DVD player to receiver via DVD input; and
3) Receiver to digital flatscreen TV.
Sound seemed to be working for awhile through my speakers, but now is not. I am not the only one using the system, and my wife is not quite as certain with all of the buttons.
How can I get sound through my speakers?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you are not able to get any sound from your receiver then first check the connections:
How To Hook-Up Sony STR-DG800
Sony STR-DG800 User Manual
If still the issue is not resolved then it means that the recievers input has a component problem or the output device hooked up to the receiver is not working properly.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Posted on Sep 24, 2009
Hook up hdmi cable to receiver input have picture but no sound
HDMI is funny about having sound problems--it does not like to be connected when units are on or even powered up.
Does the receiver have any other hookup options?
about the only suggestion (presuming all is now connected correctly) is to remove power from TV, receiver, box if used for a while---make connections then power everything back up to see if when one or all units reboot it will work or not.
Jun 17, 2012 | Sony STR-DG800 Receiver
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
How to reset sony str-dg800 to factory settings
For the STR-DG800 you need to power off. Then hold power button 5 seconds. When "push entrer" appears on display push "memory/enter" button. System will turn off and reset.
Nov 17, 2010 | Sony STR-DG800 Receiver
I am unable to hear the sound from my TV thru the Receiver Audio amplifiers and speaker
check your connection be sure that the input terminal you plug in your tv is the input terminal that you selected on the input selector of the reciever.
Aug 19, 2010 | Sony STR-DG800 Receiver
Sony str-dg800. Pre-amp out has no signal.
Hello. Jacks you are refering to are surround preamp out only. If you want full range audio out use video 1 audio out or video 2 audio out. The set does have a mono subwoofer out. You could have to go into the menu and turn it on but that is where you are to connect a subwoofer to . Larry's Electronics. ledstiles@hotmail.com
Apr 25, 2010 | Sony STR-DG800 Receiver
Sony Model: STR-DG800
You've got a short in one of your speaker wires either at the receiver (most common) or at the speaker itself. you should only have a 1/2" of each side of the speaker wire stripped to put on each terminal, and when you strip them, twist them so there are no frays in the strands that will touch the other terminal. The receiver is protecting itself from harm. Turn it off then disconnect all speaker wires, examine each wire carefully before reinstalling, then turn the receiver back on. If it still says protection, look at each speaker and reconnect your wires the same way. If you still have a problem, disconnect the wires again at the receiver and turn on, at this point, if it say's protection, it needs to be serviced. Hope this helps
Jun 23, 2009 | Sony STR-DG800 Receiver
Can't get Playstation3 sound through the STR-DG800 using HMDI.
Do you have your ps3 connected to the TV with HDMI and then audo cables from the TV to the receiver? If so, you need to make sure you change the audio settings on your TV to surround sound.
May 12, 2009 | Sony STR-DG800 Receiver
No Video or Audio on HDMI on Sony STR-DG800
The sony device may not be able to support the Toshiba. Make sure that is completely compatible and that you have the correct cables and setting to support everything.
Dec 31, 2008 | Sony STR-DG800 Receiver
STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Jul 06, 2008 | Sony STR-DG800 Receiver
Sound Problems
are u runing dvd player to tv 1st audio and video and eco meens tv is on with sterio same time erther one or other run the the dvd audio to dvd in on sterio and video cables to tv only dont use souind on tv just sterios if u want tv sound tooo use tvs rca outs back into sterio on a ch tv in ok
Jan 24, 2008 | Sony STR-DG800 Receiver
Sony STR-DG800 Receiver Logo
211 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
