Question about Cell Phones
Was changing nam settings then dropped phone without getting the last 4 #'s to unlock.
How do tyou unlock your phone if you changed the setting to nam 2
So you're playing with all the settings in your phone and you notice this nice security menu. Wow, maybe you should enable the lock code. But you don't want to have to enter the lock code all the time, so you set your phone to only need a code when it turns on. Ah. Some piece of mind. What's this other sub-menu? Network? What's a NAM? Hmm. Let's set NAM 2 and see what happens. EEEK! Your phone's rebooting. Why's it doing that? Okay. Here's that new prompt for the security code. It's okay. I remember it's the last 4 digits of my phone number. Oh No! That didn't work. Unfortunately, when you switched to NAM 2, you switched your phone over to a different phone number. Your code's no good. Your phone is useless.
There are 2 solutions. The safest and best solution is to take your phone back to Verizon and have them reprogram it. A few people have told me Verizon is uninterested in doing this. A more risky solution is below. It will reset your phone to its original settings and erase all your phone numbers you have in the phone but it should get your phone working again. I've never had to fix this problem on my own phone, but a bunch of people have emailed me their thanks to say that this works. If this doesn't work or you make it worse, please don't blame me, especially if you don't follow the directions very carefully. I believe this proceedure works, but there is one mistake that if you dial a 9 at just the wrong moment, then you're going to be guaranteed making a trip to Verizon (so speaks the voice of experience). So, without further ado, here's the proceedure:
Do this exactly:
  • With your phone on, dial 47*68#13580
  • This will bring up a menu that says something like "-TEST CDMA-"
  • Dial 22
  • Your phone will now say "Send NAM 2"
  • Dial 222222 (the number 2, six times)
  • With each key press two digits will appear on your screen. Something like "000000-84100". Write down the 3 digits after the dash (e.g. 841). These are the first 3 digits of your unlock code.
  • Dial #
  • Dial 73
  • Your phone will say "Clear All." and it will just sit there for a while. Don't panic, just let it clear all the settings. It's not clearing the programming, just all the ringers and key beeps and menu settings that you entered (and more importantly, its reseting your password to something predictable). After about 30 seconds a "." will appear after the 73 you dialed. when that happens, the menus are cleared.
  • Dial 02
  • This will reboot your phone.
  • When the phone finishes restarting try the 10 possible security codes that start with the 3 digits you wrote down (e.g. 8410, 8411, 8412, 8413, ...). One of those codes should work.
  • When your phone is unlocked, switch back to NAM 1 by pressing Menu, 0 for Setup, 2 for Network, 1 for Set NAM, and select NAM 1.
Apr 19, 2012 | Samsung Brightside U380 Smartphone Verizon
My son played with my samsung sch r450 phone and changed NAM settings I forgot code...How do I recover a 4 dig code?
Enter this code #43574357* and device information comes up. Choose system information. Use the last 4 digits of the MDN OR MIN (they should be the same) for the lock code. When the phone is unlocked, you can change the NAM back =)
Sep 12, 2009 | Cell Phones
Changes NAM Settings?
Here's some ideas for unlock codes, most phones use the last 4 or possibly 7 digits of the phone number, 4 or 5 - 0's or 12345.
Basically your NAM settings contain the phone number info for a carrier, and you can put two different numbers in the same phone using NAM1 and NAM2, what you have done is switch it to an empty NAM so it is asking for the rest of the programming info to set it up.If you can switch it back to NAM1 it should work again. Most phones have an option in the menu for phone settings that allows NAM switching without needing a code.
Aug 30, 2009 | Cell Phones
I accidently changed the settings to NAM 2 and my phone locks when it's turned on so now i don't know the lock code so i cant get back into it to change the settings back to NAM 1
...this was under 'tips' on this website...
Try typing #pwd# and then "send. It will reset your password to the the last 4 digits of your phone number. Then you can reset your password... written by MrJLH
Jul 19, 2009 | Samsung Glyde SCH-u940 Cellular Phone
How to unlock my hue 500 cell phone
The last Four digits of your Samsung R500 cellphone number is the unlock code.
To reprogram your phone i.e. change network, do the the following.
Manual Programming: * Power the phone on * Select menu then go to settings * Press * followed by 123580 * Go to NAM programming then hit OK * Select NAM 1 and press OK * Press OK then enter the MDN followed by OK * Go to MIN and hit OK * Enter MDN followed by OK * Press the left soft key to exit the phone will power cycle and programming is now complete
The Alltel Samsung R500 uses the following programming:
* Power the phone on * Enter ##626# * Enter 000000 followed by OK * Select NAM Programming * Select NAM 1 * Enter MIN followed OK * Enter MDN followed by OK * Press the red END key and phone will power cycle, programming is now complete
The CriKet Samsung R500 uses the the same programming as the Alltel but it's subsidy unlock code is: 333333
Jul 05, 2009 | Samsung Hue (SCH-r500) Cellular Phone
I forgot unlock code
This worked for me Thank Oxzgen from omgili.com
http://www.omgili.com/jmp/jHIAmI4hxg9kf_ixKeaBu9msccDGZfaj8Tp2CgQqtGDEJQ_7vJwV1ksniy7rGbKYY4PhKAtptB4XFO38fDtJZUxJoawCb1qPMpLJOL7AwKj0PSS6g60v9RGBmObIo2QKSHx5nJsiNCs-
OK... This is a little confusing and I didn't think it up (I wrote the part about HashCalc to adapt this method to the Juke). Here it goes:
Theres a number on the back of the phone: its 14 characters long... This is a MEID Hex code. It's not in the format you need to unlock your phone; you want ESN Hex which is 8 characters long. You need HashCalc (Free Program! Google it!) to convert it to ESN.
Pre.1) Open HashCalc
1) Set the [Data Format] (Drop-down box option at the top)
2) So you enter the 14 character code in the [Data] box.
3) Then make sure the box is checked next to the [SHA-1].
4) Then click [Calculate] at the bottom of the program.
5) Take the last 6 digits of the SHA-1 code.
6) Add 80 to the front of the code.
ie. Say the code was: 9a00297d20c0ef27c7afad981abbbad417045a64
Take the last 6 characters = 045a64
Add 80 to the front = 80045a64
This is the ESN Hex code I was talking about.
Now to convert the ESN Hex to your unlock code. I didn't make this part up...
7) Open your Windows Calculator (Sorry Mac Users!).
It's in Start Menu > All Programs > Accessories > Calculator
8) Set the calculator to Scientific Mode (in the view menu).
9) Then click the circle next to Hex to change to Hex mode.
10) Make sure your Hex mode is Qword (to the right of the Hex option)
11) Enter the 80****** code you created.
12) Change from Hex to Dec without clicking [=] or any other key.
13) The Lock Code is the last 4 digits of the Dec number.
Thats it! Theres your code. It worked with my Juke!
Apr 05, 2009 | Samsung SCH-U470 Juke Cellular Phone
Changed nam on phone that changed lock code,need unlock code
when phone turns on it probably says something in the way of needs initial set up or something simular? at that screen just hit clear button which will take you rt back to default screen then hit center menu button go to settings and then to phone settings,nam and chaNGE back to nam1,hit ok . phone will restart and come back on with everything normal again,let me know if different happens!
Mar 11, 2009 | Samsung SCH-u550 Cellular Phone
Unlock
just press 2945#*# the factory reset.
Jun 08, 2008 | LG C2000 Cellular Phone
Cell Phones Logo
87 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
