Question about Westinghouse Dryers
I have a westinghouse attic fan through the roof with no cap.
I have a westinghouse attic fan through the roof. it is missing the outside cap. i was hoping i could find just the cap so i don't have to replace the whole unit. do you know where to get parts? i only have a serial # 322p-129 thanks
2 Suggested Answers
SOURCE: Replace old attic fan motor, or replace the entire fan assembly.
I am assuming you replaced your fan by now. However in the future call Gibraltar Industries, they are the ones who manufacture all fans and motors. My attic motor fan also died and I first called Ventamatic and they wanted $65 for a new motor. I then called Gibraltar and they shipped one our for free. 800-527-1924.
Posted on May 17, 2011
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
I have a coleman modulating furnace it is propane The buners seem to be corroding
There are 2 types of burners. Atmospheric (or ribbon) type & inshot. I would imagine yours are Atmospheric...the longer type burners that protrude into the heat exchanger if they are corroding. Which also means you have an older furnace. Condensation can occur if there is not enough removal of flue gas...or... water is getting down into the burner from the flue. Have someone check the draft pressure to see if it has a proper draw when running. Coleman Evcon also made a furnace that is called a blendaire system. This system has a lower control board @ the furnace & and upper control board in a fan on the roof. The purpose of the fan was to blend air into the return from outside via roof fan to introduce fresh air in a tightly enveloped manufactured home, along with pressurizing the attic space to help keep the attic dry. If you have this type of system, your motor may be not working on the roof. Good luck!
Dec 02, 2014 | Heating & Cooling
I am looking for a umbrella cap to cover my 15 inch attic exhaust fan
Many people just use large black trash bags secured with duct tape or bungi cords. Black bags won't deteriorate as fast as the white ones with the UV rays of the sun and should last one full winter.
If you're concerned about the neighbors complaining about the lack of asthetics....I can't help you.
I never cover attic vents nor recommend them to be covered, because a properly vented attic all year long ensures moisture removal from the attic area and from the insulation. Also if you have shingled roofing, each nail point extending through the sheeting will condense moisture and drip into the insulation in a non vented attic space. This happens many times each winter when the air temp and the moisture content collide on the dew point scale. It does NOT happen daily.
The nails conduct the warmth to the outside, cool down and attract the moisture from the non vented air on their exposed length and slide down to the tip dripping into the insulation. Moisture detracts from the insulations ability to do its job, and that's to insulate the living space from abnormally cold or hot temperatures.
Apr 20, 2014 | Speedi-Products 6" Galvanized Umbrella...
Coleman furnace
Is this a blend air system? If so, there is an upper & lower control board that communicate to each other, and if the exhaust fan on the roof is out, it will give you intermittent issues. The fan mixes or blends outside air with the return of the air handler, & duals to pressurize the attic. These were installed due to mobile homes built too air tight. Without this fan, your roofing shingles will curl, and your roof decking will bow prematurely.
Dec 22, 2012 | Coleman Mobile Modular Home Gas Furnace...
How do we install a solar attic fan to our house?
If you have basic carpentry skills it is a 6 on a scale of 10 for difficulty. You must cut a hole in your roof, install the fan and flashing that comes with the fan then replace the shingles that were removed in the process
Jul 06, 2012 | Honeywell Solar Powered Gable Mount Attic...
Cold air is coming in from outside, didn't do this before.
Look up into the duct if possible. There should be a damper in the duct called a "backdraft damper" that closes and prevents cold air from entering the duct when the fan shuts off. The damper could also be located near the outlet of the fan which could be a wall or near the roof level (maybe in the attic if it goes through there).
Dec 17, 2009 | Gaggenau AH 600 Kitchen Hood
My Panasonic FV-11VQL2 seems to have the damper stuck in the closed position. The fan does not exhaust well, ever since we got a new roof (vent and 4" duct too). Any way to unstuck it without going into...
Hubby went into attic. The roofer did a poor job installing the new 4" duct and roof vent; duct was poorly attached and pinched at both ends. He redid both connections, and now the fan works well----no more foggy, drippy mirrors!
So, the fan is fine------the installation of the new roof vent and duct was shoddy.
Aug 24, 2009 | Panasonic Dryers
Jun 26, 2009 | Ventamatic Gable Mount Power Attic...
Broan attic ventilator appears not to be working
Did you check to see if the motor was warm or made a noise?
May 19, 2009 | Broan-NuTone Nutone Aluminum Dome power...
Airconditioner problem
This unit has a bad Start/Run Capacitor or a bad Fan Motor! Replace the $10 Cap...An then the $90 fan motor if the Cap dont solve it!
Oct 01, 2007 | Heating & Cooling
Dryers Logo
Top Westinghouse Dryers Experts
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
