Question about Motorola Mobility i880 Cellular Phone
What do u do when the screen goes upsidedown - Motorola Mobility i880 Cellular Phone
  • sungji May 11, 2010
    GENERAL PROBLEM
    » Nokia Solution » Motorola Solution » Sony Ericssion Solution » LG Solution » Samsung Somution
    UNLOCK CODE
    » Nokia Unlock Code » Motorola Unlock Code » Sony Ericssion Unlock Code » LG Unlock Code » Samsung Unlock Code
    joti18
Fix screen its upsidedown
Hi There,
Pressing the key combination CTRL+ALT+UP or CTRL+ALT+DOWN will change your screen back to it's normal position.
You can also do this through the video manager control panel by right clicking on your desktop and selecting properties.
Jun 07, 2012 | Computers & Internet
Display is upsidedown
Hit the CTL-ALT and your up arrow key.
Regards
Zahc
Jun 19, 2010 | Computers & Internet
The screen displays upsidedown
Try pressing and holding Ctrl, Alt and then any of the four arrow keys (Example:Ctrl-Alt-Down will rotate screen by 180 degrees)
Sincerely, CBR2009
Dec 30, 2008 | LG Flatron L1510S 15" LCD Monitor
Screen upsidedown
Hello agahan
My guess is that you have an Intel Extreme Graphics card in there. After doing some looking around, it looks like there is an adjustable option that will let you rotate the screen as needed, and there are 2 different ways to address it:
http://www.computing.net/answers/windows-2000/logon-screen-is-upsidedown/62429.html
From the Forum:
"To stop it happening again right-click on an empty area on the desktop, click on 'properties' then on the 'settings' tab followed by the 'Advanced' button. On here there is a tab relating to graphics, mine says 'Intel(R) Extreme Graphics' click on the tab then on the 'Graphics properties' button, choose the 'rotation' tab and remove the tick from the 'Enable Rotation' - remember to click 'apply'."
It is also noted that you can try Ctrl+Alt+Any Arrow to adjust the direction of your view. Check on both of those, and see if that helps.
~Cactus
Sep 17, 2008 | Dell Inspiron 1300 Notebook
Screen image is upsidedown
Hold down the CTRL+ALT keys, and hit the Up arrow on the keyboard.
Aug 01, 2008 | Dell Inspiron 710m Notebook
Inside screen is upside down
the LCD needs to be replaced....take it to a mobile service center and have them fix it for you.
Mar 16, 2008 | Motorola Mobility i880 Cellular Phone
Main screew upsidedown
i have only seen that once before- you can try to flash the phone, but it may have some flex cable damage
Jan 23, 2008 | Nokia 8800 Cellular Phone
SCREEN GOES BLACK AFTER 1 MINUTE
In electronics dust has nothing to do. cleaning will not solve your problem your problem is due to trouble in vertical section. mostly it is due to electrolytic capacitor in vertical section is defective.it is common problem. also check supply to vertical section. "THE SCREEN SHRINKS TOWARDS THE TOP OF THE SCREEN FOR A FEW SECONDS BEFORE THE PICTURE TURNS UPSIDEDOWN THEN TURNS BLACK." is called fold over. regards thanks
Sep 12, 2007 | Sony KV-32S42 32" TV
Motorola Mobility i880 Cellular Phone Logo
63 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
