Question about Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black
My oven makes an electrical burning smell when preheating. 1st time happened was the back stove burner. that stopped, now oven made same smell. what could it be? an electrical short? scared to use it. It is about 18 months old, and has never had this problem before.
    President:
  • Frigidaire Master
  • 1,922 Answers
How old is the unit and can you hear any odd electrical arcing noise from the unit,? outside of the usual low hum of the elements heating up?
Posted on Sep 24, 2009
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Baking
I sounds like an issue with the pilot light. Our stove does the same. Sorry that's not much help
Jul 23, 2012 | Jenn-Air JES9750 Electric Kitchen Range
Oven won't heat, display out, gas burners on stove
Hello, you will probably need to pull it out and put it on something. Make sure the breaker is off to it before you test it. There is a thermostat in the very back that could be bad,check for continuity on that. Also check for continuity on the bake and broil element terminals itself,even though you have checked it to ground. If those check good,then the problems is in the control board.
Thanks
May 31, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven smokes and smells like burning plastic
This happened with my oven, happened twice to the same (newer) oven actually. The smell and smoke occurred both with the oven and with the use of burners on stove top. Turned out it was the main line cord which had a split. The first repair they replaced the thermol block and all the bolts holding it into place (for a total of 9 parts) the second time (about a year later) the repairman replaced the line cord and said that it probably should have been done along with the first repair. The smell coming from the oven before the repair was a toxic burning wire or burnt plastic smell. There was also smoke if the oven was left on long enough. The repairman said that the amount of heat to "cook" the connection on the line was at a fairly dangerous level. It was recommended to me by the fire inspector (who was in my unit for annual condo inspections) that it was unsafe and to have it repaired immediately. Hope this helps. Best of luck.
Oct 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Top of stove hot when oven on
I suspect this may have been happening for quite some time and you may never have noticed it. MANY ovens vent near one of the stove eyes. If you lift the cooktop for 'servicing', I bet you see the little vent. It is usually in the back right underneath the cooking surface. Check to make sure it is not blocked, clogged or has rusted out/off.
Mar 04, 2009 | Magic Chef 9815 Electric Single Oven
Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black Logo
976 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
