Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Since our neighbors got DishNetwork our second TV randomly changes channels. Can I program to a different frequency?
  • 56 Answers
This is due to a " remote war" you will need to cahnge your tv remote adress to a differnt number: Dual-Tuner receivers can have the same remote address for both, but ONLY if one remote is IR and the other is UHF.
Note: If you start this procedure and at any time do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Other UHF and UHF Pro receivers should be powered off before beginning.
  1. Verify the remote is a DISH Network remote. Look for the DISH Network logo on the bottom of the remote and Mode buttons or lights at the top. Why?
      We have the codes for all DISH Network remotes and would be happy to help you with your DISH Network manufactured remote. Please contact the manufacturer of your remote for further assistance. Detailed instructions may be included in the owners' manual that came with your equipment. If not, there may be a toll-free technical support number listed.
  2. If using a remote with Indicator Tab (3.0, 4.0, 5.0, 5.2, 5.3, 6.0, 6.2, 6.3) verify the Tab is configured for the correct receiver operation. How to?
    Green Indicator Tab with a green 1 Green Indicator Tab with a black 1 Green Indicator Tab with a green 1 UHF Blue Indicator Tab Black Indicator Tab Silver Indicator Tab IR UHF Pro Only UHF Pro Only UHF Pro Only UHF & IR UHF Pro Only 522, 625, 942
    TV1 942 only
    TV 522, 625 only
    TV1 522, 625, 942
    TV2 501, 508, 510, 721 381, 811, 921
      Reconfigure Remote
      1. Remove battery cover.
      2. Confirm remote is configurable. Note: if remote label says "IR", it can NOT be reconfigured.
      3. Place thumb nail between the colored piece, above the number, and the body of the remote. Pull down towards the bottom of the remote.
      4. Turn colored piece over to desired format and reinsert until a "snap" is heard.
      5. Replace battery cover.
  3. With the receiver on, press the Info or System Info button on the front panel,
    if not present remove the Smart Card and wait 5-10 sec,
    if no Smart Card power the receiver off from the front panel and press the up or down arrow button.
    System info will appear on screen. (This procedure is not applicable for the DISHPlayer or the DishDVR 721)
  4. Press and hold the SAT button (about six seconds) until all mode button backlights come on, then release.
  5. Use the number buttons to enter a number from 1 to 15. The light will blink off after each digit is entered and then return to a steady light.
  6. Press the POUND (#) button. If the code entered is valid for the remote, the SAT mode light flashes three times.
  7. Press the Record button. The number in the Remote Address field should match the one you input.
  8. To verify the code, press and hold the SAT mode button until the mode lights come on. Then press the POUND (#) button twice. The light will flash the address.
  9. Reinsert Smart Card
Posted on Nov 12, 2009
I cannot change the channel on Westinghouse TV. Model SK-19H2105 - Tried to do the fix mentioned for channel scan - cannot find the channel scan.
Press the “Menu” button on your remote or the side panel to access the On Screen Display
(OSD)
—Use the right/left arrow buttons to scroll across to the “Setup” menu
—Use the up/down arrow keys to select “TV” and “Quick Setup”
• Use the arrow keys to select your “Time Zone”, which allows you to receive
proper HDTV programming information
• Continue with arrow keys to select your signal source “Air/Cable/IRC/HRC”
—If you use a rooftop or indoor antenna, select “Air”
—If you use a cable service, select “Cable,” “IRC” or “HRC” (depending on the frequency
used by your cable service)
—Press the left arrow key to start scanning for channel
Aug 16, 2016 | Westinghouse Televison & Video
I have dish network and its programmed to work on channel 60 of the TV set, but lately the TV has began changing to a random channel from the "Favorite Channels" list and its making watching...
Hi my nameis Mike Houston of DISH Network and I see you have the TV setup to watch yourprograms on channel 60 and the TV is skipping off that channel. You want tomake sure the TV is on channel 60, make sure the remote is in SAT mode and tryto go to different channels and make sure it stays on the satellite channels.If you have any questions please e-mail me at michael.houston@dishnetwork.com.
Dec 08, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Cannot remove program information appearing on tv. It's bothersome. How can I remove this channel number,time and program information?
Hello! my name is Dan Busa with Dish Network customer support. If its just popping up randomly, there are two things you can try. You can unplug the reciever for ten seconds, also you can readdress the remote either option should resolve this. Here is a link with instructions: http://www.dishnetwork.com/SupportSection/remote-setup
Nov 27, 2010 | DISH Network 311 DTV Receiver
Light will randomly turn on and fan will randomly shut off or switch to high speed by itself.
Howdy,
How close are you to your neighbors? It's possible that one of your neighbors has a fan which is on the same frequency as yours, look in your remote and you will see a bank of little switches.. Find the receiver in your fan and you will see another bank of switches, change a couple of them to a different position, making sure both match and see if your problem does not go away. If it does, yay, if it does not, then it's possible you do have a malfunctioning receiver.
Thanks
Sep 19, 2010 | Hunter Ceiling Fan Remote Receiver...
Is there anything in a PC that can cause interference with a wireless network? Because firefox ate my earlier question, I'll keep this short: PC used to keep laptop from connecting to internet when it was...
there is nothing inside a PC that will keep it or anything else from connecting to a wireless network. You have to lookout for things that use the same frequency such as cordless phones and believe it or not microwave ovens. both broadcast at 2.4Ghz which is the same frequency wireless routers and access points use. Your problem may also be a neighbor with a wireless router or access point using the same channel. Wireless routers and access points have 11 different channels that they can broadcast on and if you and your neighbor are using the same channel there will be interference. try changing the channel on your wireless router or access point.
Apr 14, 2010 | D-Link WDA-2320 (ASKU54036) Wireless...
How do you set up the scanner to scan police and ems channels
First you'll need a list of frequencies to program. For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Once you've selected your frequencies, power the scanner ON and
1. Press E/PGM to enter the program mode (the scanner turns on the
PGM icon).
2. If the current channel is not the one you want to program, enter the
memory number then press HOLD.
3. Enter the frequency including the decimal point, then press E/PGM.
4. To program the next memory, press  or  and repeat step 3. To
program a different memory, repeat from step 2.
5. To exit program mode, press HOLD or SCAN or change the scanner’s mode.
Notes:
• Any frequency you program replaces the previous memory contents.
• If you enter a frequency you have already stored in a different
memory in Step 3, the scanner beeps and displays the channel
where you have previously stored the frequency. If you want to store
the frequency anyway, press E/PGM a second time in Step 3.
• To clear the contents of a memory, enter “0” in Step 3.
• Channels you program are automatically unlocked (see
“Locking/Unlocking Memories) and have Delay turned on (See
“Setting Channel Delay”).
If you would like to download/print the operating manual for you scanner, visit:
http://uniden.com/pdf/BC340CRSom.pdf
BillB
Jan 11, 2010 | Uniden BC340CRS Base Scanner
Cuts on and off and changes channels
change your tv chanel program button or its problem in programing devise or video frequency
Aug 28, 2009 | GE 31GT740 31" TV
How to change channel
Spirit GT: Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jul 17, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
How do i change the channel?
Selected Channel:
frequencies. Figure 16.
Jun 25, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
Cannot set Cable Default Channel
I believe you are getting mixed up between channels and programs. Normally program 00 is used for VHS as it has slightly different parameters for colour and brightness. If the TV has about 39 or more programs which can be programmed in from the on screen menu, try using program 20 for the video and 30 for the cable. For this to work you must do the on screen frequency scanning from channels 22 to 69 (UK) and select VCR, CATV, VHF, UHF, etc. I have used program 00 and 20 for two VHS recorders, working on channel 33 and 35 for example, but you must tune them to 33 and 35 on the `Tune' screwdriver hole by the aerial input sockets of the recorders. I expect if your cable unit plugs into your aerial socket of the TV that it has an adjustment for what channel it is on. The TV on screen menu may be different in some countries, so it would help if I knew where you are.
Oct 21, 2006 | RCA F32632SB 32" TV
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
270 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
