My Onkyo cr 305 tx CD Recivier CD rack went out
It has a 2005 built date need to know if it is still under warrenty, if not where can I get the cd rack to replace it. the problem is when you put a cd in it ,it takes it in ,then it takes it out.
Gzamb40340.1@sbcglobal.net
SOURCE: onkyo tx-nr801 net tune setup help
Below is the sequence that I made it work
1. download the latest firmware for tx-nr801 and net-tune central software at Onkyo website as shown below:
http://www.intl.onkyo.com/products/net-tune/download/index.html
Click on "User Identification" at the bottom
(You'll need the serial number shown at the back of TX-NR801
to download it)
2. disable firewall in your PC or notebook and start
updating the firmware for tx-nr801
If firewall can't be disable, you probably can't go through this.
This step takes about 30 min.
(There is a document showing how to do this with the download)
3. keep disabling firewall in your PC (notebook) and install net-tune central (there is similar document describing the procedure too)
4. By pressing Net-Audio on remote controller (it can switch between mServer and iRadio fucntions if you keep pressing this button)
Posted on Nov 30, 2007
SOURCE: Recording audio on the Teripin CD Video Recorder TX-0002
There are TWO differences between STD CD-R and those labelled MUSIC/AUDIO by the manufacturers. One is financial, the other is technical.
Firstly, if a CD is labelled MUSIC/AUDIO and sold within the USA, the manufacturer pays a royalty to RIAA as a way to compensate its members.
From a technical standpoint, the CD has a 'flag' on it that describes it as MUSIC/AUDIO and it is optomized for recording at 1X speed.
Kind Regards
Posted on Jan 14, 2008
  • 211 Answers
SOURCE: Wurlitzer New York Model CD Jukebox Manufactured around 1992
How do you get the arm back over the carousel so you can play a CD initially?
The gripper motor is powered by the K6 switch which is a copper wiper ring you can see at the end of the gearbox. If that is dirty or has a dead spot it will stop the motor before it should.
Posted on Mar 20, 2008
  • 3 Answers
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
SOURCE: I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Posted on Oct 18, 2008
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
ONKYO CR-315 cd player locked.
Hello
Just try to reset the CD receiver by holding the clock call button and pressing the STANDBY/ON button.
Nov 30, 2011 | Onkyo CS5VL Super Audio CD Player Black...
How to connect a turntable to Onkyo txsr 500
Just like most contemporary AV Receivers, there is no built-in Phono preamp in this unit so if your TT doesn't have one internally, you'll need to get an aftermarket Phono Preamp somewhere to PREamplify and frequency-balance the minute Phono Cartridge output to a useable Line Level you can send to any available Line Level input on the Receiver (CD, Aux, whatever) .
Feb 06, 2010 | Onkyo TX-SR500 Receiver
Connect mp3 on onkyo tx-ds484 ?
buy an attachment at Radio Shack - Ipod cable to 3 rca cables; plug the rca cables into the
CD input; leave the video cable hanging. It is not a charger, so you will need to re-charge your ipod.
Dec 27, 2009 | Onkyo TX-DS484 Receiver
2005 Honda CR-V won't go to XM radio.
"XM Ready" means that you have to have a satelite radio installed in order to have XM service. I went through this when buying my 2005 CR-V and thought that all I needed was to set up the service. If you have an XM receiver installed you can controll it on your Honda factory radio. It is very misleading.
Feb 28, 2009 | 2005 Honda CR-V
How to program onkyo tx-sr606 receiver onto remote control
I think onkyo has not come up with codes for game console yet. Codes that are available are for DVR/VCR, CD, DVD, TV. and Setup Box. I need to get the manufacturer of those components that you have for me to be able to determine which code is appropriete for your components.
Nov 23, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-DX838
I went back and found a loose cable/coax. Re-attached and now the receiver works as good as ever.
Sep 02, 2008 | Onkyo TX-DS838 Receiver
New receiver....old CD, record and tape players
Most new recievers don't have a "phono" input. If your record player is an older kind without a built in preamp, you will need to purchase a Phono pre-amp (about $25) and then you can use any input you wish.
Sep 13, 2007 | Onkyo TX-SR304 Receiver
75 people viewed this question
 Grubhead
Grubhead
