Question about MSI K8N Neo4-F Motherboard
Extremely annoying problem
Hi I'm kind of a newb with hardware problems because I just built my own computer and I'm fourteen. My computer originally worked fine but a few days after I finished it it randomly shut off. It then immediately tried to start back up but it got stuck on the very first screen where it gives you the option to switch to POST mode or go into the BIOS settings. I couldn't figure this problem out for over a year and sent the processor back but that wasn't it. Then I just tried to turn it on and it worked. I didn't understand this but I didn't care. But then it happened again and I took out the processor and it worked. So I thought that had something to do with it but now it has happened again and nothing I do seems to work. I've called MSI my m/b manufacturer but they just told me to reset the BIOS and that didn't work. My computer is running an AMD Athlon 64 2.4 Ghz socket 939. You know my m/b model. I'm running a gig of RAM in two 512 megabyte sticks. I'm pretty sure they work. I've never had any problems with my hard drive so I'm pretty sure that's not it. I have a NVIDIA e-Geforce 7900 GT. That seems to be running because I am getting an output signal since I see the first screen. I have had the power supply tested and it's working fine. Can anyone help me with this? I'm at my wits end.
Thanx all
  • Theo Linnemann
    Theo Linnemann Dec 16, 2007
    I already tried that and the washers are fine. All my drivers are up to date.
  • 482 Answers
Some times the drivers in it couse them to shut off and restart. tri to update the video driver. sometimes when you put in a mother board the scew's that dont have a washer can short the computer. try to losein some of them. I hope this will help.
Posted on Dec 16, 2007
  • farren wadley
    farren wadley Dec 17, 2007
    your mother board has a short
Is my display broken?
Hi try this if correct for you
Also YouTube has some people so may be you could ask after reading the instructions as it may be just an update required.
No such thing as a Newb we all start from base so you are a rung up now good luck and please reply as it can help others
Dec 26, 2017 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
No tuner error on sony media center
The problem must be either because of Hardware or software. You are saying that you already tried installing new drivers and softwares for the tuner card and checked, but its bad luck. So it seems the hardware device may be failed. So first ensure the hardware working properly by plugging tuner card into any of your friends system. If it works properly, then it must be surely software problem. We can try installing any other version of device drivers and softwares and make it work.
Goood luck.
Sep 09, 2008 | Sony VAIO VGN-AR230G Notebook
Annoying sound from the DVD player that won't stop.
That is normal for DVD/TV's the dvd is setting it self only takes about 15-20 sec. If still making noise after this problem with dvd
Nov 07, 2009 | Polaroid TDX-02610B LCD TV
Same problem, extremely annoying
Go to Speakers properties > levels > mute pc beep.
That should stop the annoying power beep but not the startup jungle.
Jul 29, 2009 | Lenovo 3000 V100 Notebook
Scanner making annoying drag lines
check first before the software problem before to proceed hardware problem...first thing, you can check to uninstall the driver of that scanner.or else try in another pc if it is working good..if not,it means theres a problem in the hardware...
Mar 03, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Screen keeps minimizing.
Mine does it ,too.Extremely annoying! Just hit Control and 0 and it will go back to normal.
Dec 28, 2008 | Microsoft Windows XP Home Edition
AVS500 powered subwoofer
I would look around for anything new in the house dif tv anything elctrical and unplug it to see if this helps
Dec 02, 2007 | Altec Lansing 621 Computer Speakers
Bad Picture quality when AC powered
Based on your post/description, your power supply is faulty.
1. It your 24VAC adapter/power supply is the original one that came with the camera, then most likely a component failure inside. More often it is the filter capacitor.
2. If it is a replacement, then possibly the ratings are not compatible with the camera, specifically the current or power (Amps or Watts).
3. In some instances the built-in regulator might be shot since your source is 24 but your load rewuires only 12.
Hope this be of some help/idea. Post back how things turned out or should you need additional information.
Good luck and kind regards.
Oct 23, 2007 | JVC Tk-C920u 1/3" CCD Super Lo-Lux Hi-Res...
DVD burning
From your cryptic description, and the extremely limited details given.
Does the DVD even show up on "My Computer"?
If it is not shown...
Go to your "Device Manager" (Right click on  'My Computer', select 'Properties', click the 'Hardware' tab, click
the 'Device Manager' button. Click the "DVD/CD-ROM drives"). If there is some kind of a "Warning" icon superimposed on the 'DVD drive' icon there is your problem!
Uninstall the DRIVERS for THAT DEVICE only.
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
Oct 20, 2007 | Computers & Internet
MSI K8N Neo4-F Motherboard Logo
69 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
