Question about Refrigerators
Water drain water pools at bottom of fridge[under drawers], doesnt go to tray beloe fridge
  • Mike Smith
    Mike Smith May 11, 2010
    Need model number to help .
    Sergeant:
    Champion:
  • 255 Answers
Find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
Posted on Sep 24, 2009
Water Pooling & Freezing
Assuming your fridge has a defrost cycle ( I.e. is a frost free model), you are probably suffering a blocked drain hole or pipe, leading to the top of the condenser or a tray nearby, where the frost water can evaporate.
The pipe can block with food or a mould plug, leading to water retention that freezes and further blocks the drain. the water is produced when a heater switches on in defrost mode and thaws the internal or external ice build up and, with nowhere for it to go it will pool on the bottom and may, when in defrost mode, run out onto the floor.
With frost free fridges/freezers, there is a drain outlet, usually hidden behind a removable panel inside the fridge/freezer compartment or, a drain hole near the bottom. If there is a drain pipe as well, access is usually from the rear base of the machine. The pipe is usually removable and can be cleaned out but prepare for some water to escape. An ice block in the drainage hole can be thawed using a hair dryer BUT GENTLY, so as not to warp the plastic inners of the fridge.
Jan 20, 2014 | Refrigerators
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
There was standing water in the bottom of my Roper refrigerator under the crisper drawers. The drain pan under the fridge was dry. I cleaned up the water and vaccumed under the bottom of the fridge. ...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Jul 31, 2011 | Refrigerators
My fridge model CTF2123AR leaks water under bottom pull drawer. this pools water on the floor
Water found under the tray is due to excess defrost specially when the fridge is set to a lower temperature due to heavy frosting.
So during defrosting the excess water flows into the tray and overflows out which incidently has flooded on the floor.
What could be done is to drain off the tank, fully defrost the fridge by shutting down for few hours and then setting the fridge/freezer to a normal temperature.
Jul 13, 2011 | Magic Chef Refrigerators
Fridge and freezer are working just fine. But, I keep getting pools of water inside my fridge. These pools stay to the back of the fridge on all levels and they sometimes turn to ice. I notice ice layer...
Your defrost drain is most likely blocked with ice or sludge. Now when your refrigerator goes into defrost it pours into base of freezer or just anywhere it can to pool up. Click Here=> Leaking Refigerators, just what may be happening Click here also=> Leaking Refrigerator's? Please let me know if you still have questions, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool Refrigerators
Bottom of fridge collects water
Hello there:
I have written a few steps for you to follow and try ok?
  1. Manufacturers have different ways to dispose of the water created during automatic defrost cycles. The most common design routes the water down a rubber tube on the back of the fridge to a tray beneath. This tube often gets plugged with breadcrumbs, peas etc. and can generally easily be removed and cleaned.
  2. Make sure the end of the hose is sitting in the defrost tray.
  3. If your hose was not plugged and you have found water running down the back wall inside the fridge or a pool under the bottom crisper has formed. Check if there is a small funnel located on the back wall near the top inside the fridge. It can also get plugged; you can use a small wire and work it in and out of the hole.
  4. Some designs do run the water down the back wall and have a drain hole under the crisper, make sure it is not plugged.
I hope that this has been verry helpfull for you
best regards michael
Nov 06, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Underneath the freezer drawer builds up with ice (have to chip it off a (makes opening the freezer difficult) and sometimes when I open one of the fridge doors (does not matter which door) water pools...
it seem that you have a clogged freezer drain. you can fix this by first turn off the unit leve all door and let it thaw about 4 to 6 hours or longer. if this doesnt cure the problem then repeat above procedure but this time open the plastic cover on the freezer and clean out the drain make sure all drain are unclogged also while your at it check the operation of the drain heater pan underneath the unit. and lso check the operation of the defrost timer. hope it help you.
Sep 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water/condensation in both dairy tray and bottom of fridge
My guess is you have a blocked defrost drain. The water instead of going down its drain goes down the backside of the frig and pools up under the crispers. Blow out the defrost drain. The only other thing to look for is bad door gaskets.
Dec 16, 2008 | Refrigerators
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
Leaking Whirlpool refrigerator
My Whirlpool fridge had water droplets falling onto all three shelves and pooling unter the crisper drawers. I solved the problem by clearing the ice-clogged drain in the freezer.
In Whirlpool model ET21UM, the condensation drain hole is located directly behind the freezer. To access the drain hole, remove all your frozen items and place them in a large picnic cooler. Notice that the floor of the freezer is basically a large plastic tray fastened by two small bolts. Unscrew the bolts with a wrench or ratchet and remove the plastic tray. At this point you will probably see that water has seeped under the tray and created a mini ice rink on the bottom of your freezer. You can tap the ice lightly with the handle of a screwdriver to break it up. Once it's broken, toss the ice into your sink, or put it in a plastic bag and store into your cooler to keep everything cold.
Once the ice has been removed from the freezer floor, you should be able to see a metal drip trough in the back under a false wall hiding the condenser coils. It's a little tougher to remove the ice from the drip trough with the screwdriver method, so you might want to use a hair dryer. After a few minutes with the hair dryer, you should be able to remove most of the ice by hand. You can remove any water with a sponge or turkey baster. The only ice left will be a plug of ice in the drain hole in the middle of the drip trough. Heat up a cup of water in the microwave and carefully pour it into the drip trough. If the drip trough is hard to access, you might need to use a funnel. The hot water should melt most of the ice in the drain hole. If it pools in the drip trough and doesn't drain, use a sponge or turkey baster to remove the water and add hot water again. A small length of wire or a pipe cleaner might help clear any other obstruction in the drain hole. When the drain is clear you should hear water flowing through it. Dry off the floor of the freezer and return the plastic floor tray to it's spot and fasten with the two bolts. Remove any water that has pooled in your refigerator and you're done.
Dec 27, 2007 | Refrigerators
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
