Question about Garden
Loss of pressure with Craftsman 7.25hp, 3000psi pressure washer
I have a craftsman 7.25hp, 3000psi pressure washer that sometimes loses pressure.This has happened 3 times now and each time I replace the ball & spring in the pump and it works for a while and then the spring breaks each time. Have you ever heard of this problem and what could be causing it.
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello, it is a craftsman need i say more.
  • 14 Answers
SOURCE: craftsman 4 hp 2150 psi pressure washer wont start
Go to www.karcher.com ,click on your region and then click international. Enter the model of the machine or the type number . That is is the first 8 digits of the number under the barcode. This will take you to the parts listing for your machine.
Posted on Mar 11, 2009
louislevel_2
  • 374 Answers
SOURCE: I have a craftsman 3000psi and it keeps losing pressure
hi there,
this means no water pressure coming
to pressure tank it was consumed when use for cleaning, the water pump does not work,check water pump if function,if there over load reset,or had to jumper the connection of pressure switch.
jump the connection of pressure switch,by passing pressure switch if the motor run just jug for 3 seconds,if run you have defefctive pressure switch,replace pressure switch.have a nice day and rate me if your satisfied to my solution,thank's
Posted on Apr 30, 2009
  • 87 Answers
SOURCE: Briggs & Stratton 2500 Power Washer Loses Pressure Time to Time
If by "a few minutes" you mean 180 seconds, I really don't know what to say. But if you mean 5-10 seconds, you probably are experiencing air in the water line or normal engine warm-up behavior when the choke has been set to full lean too soon.
Posted on May 23, 2009
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
  • 402 Answers
SOURCE: Craftsman Pressure Washer 2.3 GPM 2550PSi
if there is a fuel filter running completely out of fuel sometimes allows all of the bad stuff in the fuel tank to plug the fuel filter (if it has one). press the primer bulb until you can hear fuel, then it should start.
Posted on Jun 02, 2010
Craftsman 580 767101 when i squeeze the handle pressure it loses pressure. If i squeeze i get a burst of pressure, it then fades out. Relese the handle and squezze i get another burst
Sounds like the inlet water source may be blocked. When you hold the trigger open, water should flow freely. If this is not the problem, it may be that the pump seals are going bad.
Jan 21, 2014 | Craftsman Garden
Engine lockup
Sounds like the intake or exhaust valve is not opening.
Jun 08, 2013 | Craftsman 2700 PSI Briggs Stratton...
Craftsman 1700 leak
craftsman 1700 pressure washer 1700 elect. with steam
it sucks down the soap down when I wash my golf cart. I do it fast any way slowing it diwn
Jan 28, 2013 | Craftsman 1700 PSI, 1.3 GPM Electric...
Where are the filters located on the craftsman 2700 power washer
The only filters on a pressure washer are: Where the hose hooks up to the pump there is sometimes a washer with a screen inside it. The syphon hose usually has a fine filter on the end that drops into the detergent. If this question is related to your other post see my answer there.
Aug 30, 2012 | Craftsman 2500 PSI Briggs & Stratton...
Jun 02, 2010 | Craftsman 2500 PSI Briggs Stratton...
Hello:
Aug 25, 2009 | Briggs & Stratton Garden
hi there,
Apr 30, 2009 | Karcher 1750 psi Electric Pressure Washer
Garden Logo
346 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
