Question about Toshiba Satellite 5205-S705 Notebook
Will not install a full version of Windows XP
Toshiba Satellite 5205-S705 Will not install a full version of Windows XP
I had to replace the hard drive and now i can not install any windows oses.
  • 615 Answers
Are you trying to use the recover disk? or new XP, what did you have in the past? you may need to use the recover disk first and see what will happen as it may contain all the necessary drivers first that you need first, let me know if that work and please remember to rate my service so I am able to continue provide quality service and improve on it with your help. God bless
Posted on Sep 24, 2009
  • 748 Answers
Hello
I'm assuming this is a brand new hard drive? If it is then it's defective. If this is a hard drive from another computer then it needs to have the old partition table removed. If you have another computer download any partition manager from www.download.com. Delete the partition and then your OS should install just fine. If you don't have another computer, you can still download a partition manager at the local library.
Good luck
How to do i enter bios setup in toshiba 5205-s705
Hold down the F1 key, then, while continuing to hold it down, press the power switch. the system will turn on, then prompt you to check system and press F2 (thats from memory, it maybe F1 again) to enter BIOS.
With many Toshibas you can hold down any key to do this, as it simply generates a keyboard error, prompting the same message.
Hope this info helps.
May 19, 2012 | Toshiba Satellite 5205-S705 Notebook
Toshiba 5205-S705 is giving an error msg boot.mgr is missing..i tried booting from xp through cd rom but didn work tried to boot with usb as well but didn work any solution pls mail prashantaishu@gmai
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 13, 2012 | Toshiba Satellite 5205-S705 Notebook
How can I install internal Toshiba MK3265GSX into my notebook with Windows XP (SP3)? Setup software can't find hard disk. Where can I find driver for this device for XP?
Hi
Disassemble the laptop, follow the bellow link for details,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-1200/take-apart-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Tecra-A2/notebook-disassembly-guide.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
For install xp follow another link,
xp setup not detect hdd http://www.microsoft.com/downloads/en/confirmation.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/ http://www.nliteos.com/download.html http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/ Hope this helps,reply me for further instruction,
Feb 27, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Insatll windows xp in satellite A300(PSAG4E)
You may need to take your PC to a computer shop or call Toshiba if the BIOS has been corrupted.
Sep 07, 2009 | Samsung (SP0822N) 80 GB Hard Drive
I have to change the body of the Toshiba Satellite 5205-S705 Laptop. I want to know how to open the laptop ?
Try this link and have step by step of disassembling of your laptop.
www.irisvista.com/tech/laptops/Toshiba1415/sat1415_1.htm
Aug 25, 2009 | Toshiba Satellite Satellite 5205-S119...
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
I HAVE A TOSHIBA 5205-S705 WHEN BOOTING UP ERROR MESSAGE INVALID BOOT.INI BOOT FROM C:/WINDOWS> AND IT IS STUCK THERE CD WONT BOOT F-8 GETS STUCK AFTER YOU SELECT YOUR TYPE OF BOOT THEN IT STUCK. HOW CAN I...
hi,
when you start your system you will always get a message on first screen del /f2 to go to setup , so press del/F2 and enter setup and here look for boot sequence and change the first boot device to optical media ie. cd/dvd then save and exit
now follow help article at the link here to be able to boot your windows
http://support.microsoft.com/kb/330184
and after that you will need to again set the primary/first boot device to again your hard disk
further queries are welcome
if you think my solution is helpfull please do rate me
Feb 21, 2009 | Toshiba Satellite 5205-S705 Notebook
Install windows XP on toshiba satellite U300
Hello
The windows Xp installation doesent find your hardrive because you have a sata drive. you need to adjust the settings in the bios so the sata drive appears as a ordinary IDE drive(ide native) or something like that. search in the bios settings.
A other way is to burn a new winxp cd with the Toshiba Satellite U300, sata drivers.
download the http://www.softpedia.com/get/System/Back-Up-and-Recovery/Barts-PE-Builder.shtml
and download the toshiba harddrive drivers and creat a new cd.
but the simples way is to make the change in bios.
good luck
Aug 18, 2008 | Microsoft Windows XP Professional With...
How to install XP in toshiba Satellite L45-S7423 laptop
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
Feb 29, 2008 | Microsoft Windows XP Professional
Toshiba Satellite 5205-S705 Notebook Logo
101 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
