Found short; repaired. Labelled connector order for re-install on main knob/VB, but did not (stupidly) notice which lugs where not used.
Runs some, no water, etc.
Comments:
Sep 24, 2009
- Not even close, yet. Power is not the problem; distribution through the 8 connectors on the lower portion of the main, 5-position rotary switch is.
I removed and numbered the 8 connectors to effect a repair. I need to know what 2 lugs are to be left un-connected. The inlet valve is not opening to allow water to flow. The circulation pump is running, though.
A picture of the right side of the rotary switch would work, or the 2 untapped connecdtions, i.e. 5a and 8b or whatever.
That would solve my problem.
Thank you, Chuck
Sep 25, 2009
- On a Viking VUD 141 dishwasher, the rotary switch and timer housing lower portion has 10 electrical lugs on the right side.
Thanks for using FixYa.First, make sure that the unit is getting power to the cord.
Next, take the kickplate off below the door. There is a silver box with wire
connections inside it's about 3" x 3". Remove the cover and look at
the wire connections. This is where your cord connects in with your dishwasher.
If the connections check good and they're not melted or shorted then you
probably have a bad control board.
A device may cease to function or operate sporadically if
the electrical cord is damaged. Inspect the cord for any of the following
damage.
Is the
wire shielding pulling away from the plug?
Is the
cord secure where it connects to the device?
Are
there black smudges or burn marks on the outlet, cord or anywhere the cord
comes in contact?
Are
there cracks in the shielding or exposed wire?
Has
the cord been pinched or bent so that the wire inside may have broken?
If the
answer to any of these questions is "yes", then the cord should
be replaced.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Comments:
Sep 24, 2009
- Hi
You can see the blown use, tripped circuit breaker, wiring
connections, door latch, timer motor and selector switch just clicking on the words shown in blue color.
Please check for ablown fuse,tripped circuit breaker Also
check that the dishwasher is plugged in securely. Inspect thewiringconnections
to the dishwasher for burns or breaks. Check thedoor latch, test the door switch, thetimer motor, selector switch, motor
start relay and even motor itself. If the drain pump is
running continuously, then there is probably a leak in the pump housing area
below the unit. Please do accept the
solution if the issue is resolved or else revert for further assistance. Thanks
Behind the front 'kick plate' is the tech sheet for the machine. It should have a schematic for the machine. there are wire numbers and colors for each wire. I bet if you study it, you will see what you need to do.
Viking double oven The delay setting will not turn off or clear - when timer setting and off is...
(More)
Viking double oven The delay setting will not turn off or clear - when timer setting and off is pushed it continues to read delay and time - what was pushed to set this and how can it be cleared?
Hi - I used the self-clean feature on my Viking oven 2 days ago and now it won't unlock and I can't...
(More)
Hi - I used the self-clean feature on my Viking oven 2 days ago and now it won't unlock and I can't any burners or the oven to work. Any advice would be appreciated.
water was shut off during dishwasher cycle not dish water will not work no water even though water...
(More)
water was shut off during dishwasher cycle not dish water will not work no water even though water is back on
Viking dw 20.3 does not complete cycle or open soap door. It does drain and fill ok . When it stops...
(More)
Viking dw 20.3 does not complete cycle or open soap door. It does drain and fill ok . When it stops both "pots and pans" and "heavy" are lit, but dishes are dirty. .Thanks, JimBringe@hotmail.com
