Question about Mitsubishi WD-60735 Projection Television
The screen looks like mountains growing from the bottom turning the tv black
  • 748 Answers
Hello
This is one or more capacitors going bad in the power supply. Take it to a reputable repair person or check out my website: www.micromendllc.com
Good luck
Posted on Sep 24, 2009
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
73' Mitsubishi has magenta splotches moving around screen and eventually getting larger until whole screen is covered.
bad main digital board. It's the bottom board on the left, try Encompas Parts to get digital board.
Nov 27, 2011 | Televison & Video
My tv has black splotches or pools on the bottom
If the splotches are a shawdowy black and look like mold growing between the Lens, its most likely dirt or water spots on the bottom of the large mirror. I cleaned mine and missed a few water spots on the bottom of the large mirror and the splotches (spots) showed on the screen. Other than Dirt, or water spots, There is nothing else that I can think of that would cause this. Unless the Someone has cleaned the screen and it soaked up between the lenes. But it Takes about 30 minutes to disassemnble, give it a good cleaning and put it back together.
Nov 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Black space
most likely cause is the light engine. you can get a replacement light engine from www.tvrepairworld.com
Dec 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Screen has black spot in corner that spreads to entire screen
one of the floresant bulbs has fail there is a place in Haverhill Ma called Tops Electronics that can fix you up really quick but you will have to ship it to them they do good work there
their new name is pinnacle solutions group over 30 year serviceing
Sep 18, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Water damage on left corner black orbs on right corner that continue to grow bigger each day. lines (very thin on screen).
My daugther sprayed cleaner on our vizio tv screen, and now there streaks and a ***** of black pixels at the bottom. Is the tv junk now? Can it be fixed? Will it get worst? Thanks!
Jun 15, 2009 | iLO 3200 32 in. LCD Television
Black growing on screen
That is normally cold solder joints around the High Voltage transformer ( IFT) and also the video section. It should'nt be a major repair for a tech.
Apr 16, 2009 | Televison & Video
Screen goes black, picture grows over time but is dark
i suspect that you have a problem in the yb board that's the first thing that i would do.
good luck
caypianan@yahoo.com
Oct 30, 2008 | Philips 42PF9630A 42 in. Plasma Television
BLACK GAP ON RIGHT SIDE OF TV SCREEN
This is a sign of an aging horizontal deflection circuit. Go through your initial setup menu and see if the set gives you the option to adjust 'width.' This may have enough range to stretch the video to the edge but it will also affect the geometry of the displayed video.
As of now, the component most likely growing old is an electrolytic capacitor in the horizontal circuit that has lost value. It is usually a bipolar capacitor in the range of 4.7 - 33 uFd. It will likely continue and become more annoying and if you look closely, you can probably see that the geometry of the picture on that side is not as it should be; it will often appear 'squashed' together.
Allowing it to just grow may result in the failure of the flyback (a high voltage transformer) and/or the main power transistor that drives it.
Sep 22, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Growing black blob
Could be dust in the optical engine? There could also be marks on the mirror? You can get a sort of a similar problem in the LG RE44SZ22 when the light tunnel becomes warperd due to heat from the lamp. Best regards, Arpi
Apr 24, 2007 | Toshiba 46HM95 46" HDTV
Mitsubishi WD-60735 Projection Television Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
