Question about Refrigerators
IIhave a kenmore refrigerator. the compresor waned to turn on but only make a click noise, i change a new the relay and the started but still don't turn on only make a click
    Sergeant:
    Champion:
  • 255 Answers
Check amp dram on compressor wires.
Posted on Sep 24, 2009
Stopped working. clicking sound when it wants to start up. Is it the compressor or the relay switch model 8 yrs old old.
You.have to check if the compresor is working or damage. Try starting direct the compresor, Generali should be the electric part outside the compresor just change at the electric parts and should work. If you send a picture of the position on the connectors I will help you to try the compressor
May 29, 2015 | LG LFX25960ST Stainless Steel French Door...
My refrigerator LG GM 313SC wasn't working yesterday, I disconnect the refrigerator and notice that the compresor was too hot, I reconnet the refrigerator at night and in the morning checked the compresor...
I have 2 of the LG GM 313SC. Purchased brand new here in the Caribbean (Dominica) Both units when I turned them on for the first time are making a 'clicking' noise that is happening together with blinking lights on the temperature control inside the fridge section.
It isn"t even turning on. The light inside is dim, which the manual says is an indication of a problem, and to call an electrician. I think not, they are brand new and behaving the same way.
Any suggestions
Oct 21, 2010 | LG Refrigerators
Does not get vey cold
What line? if its the lines on the back of the refrigerator, the ones coming out of the compresor, then check if the compresor is still running when line becomes warm, if compresor turns on and off every few minutes or so, you might have to change the overload, relay or capasitor( if equiped with).
Mar 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge kicks in louder than usual for 20 seconds and clicks off.
the pistons in side the compresor are compermized.as long as the unit contiune's to work's than you are good.there is nothing you can do to fix this.
Nov 28, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerator tries to come on but doesnt
Probably you heard a click on and off when the compresor is trying to start , that could be the relay or the compresor went bad .Try replacing the relay (no more than $30) If the compresor doesn't start is either burned or stuck and has to be replaced.
Aug 19, 2009 | Kenmore Refrigerators
Refrigerator clicks on and off but no getting cold
Try to replace the relay and capacitor off the side of the compresor under the black plastic cover ;this parts will cost you no more than $30 ;but if still the compresor won't start it means it went bad and has to be changed .
Aug 05, 2009 | Frigidaire FRS6R5EMB Side by Side...
Fridge freezer not working/power ok,
If the compresor is very hot and won't start,the clicking you heard is the overload at the compresor that goes on & off beacause the relay ,that makes the compresor start is bad or the compresor is bad ,if you know how check the compresors coil if not try replacing the relay with a same replacement(no more than $20 or $30) if still won't start the compresor needs to be replaced.
Apr 24, 2009 | Refrigerators
Not cooling - sounds like something is trying to start then clicks off
Try first replacing the relay(located on the side of the compresor)wich the part won't cost more than $20.If doesn't work the compresor is stuck or burned and you need to replace it.
Apr 19, 2009 | Refrigerators
Turns on...clicks every few minutes....never gets cold
It looks like the compresor is trying to start and goes off on overload ,it could be a bad relay or a bad compresor.Try first replacing the relay located on the side of the compresor under a black plastic cover(ALWAYS UNPLUGGED THE FRIDGE BEFORE DO ANY WORK) if that does not work you need to replace the compresor.
Apr 09, 2009 | Danby DAR482BLS Compact Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
