Question about Panasonic KX-T7630 Corded Phone
Change name assigned to handset ? - Panasonic KX-T7630 Corded Phone
  • Panasonic Master
  • 2,460 Answers
Names are assigned to phones by system program 004. Your system manager or installer has those access instructions.
Carl
Posted on Sep 26, 2009
Change imei
You cannot change an IMEI number since it is assigned by the manufacturer at the time of manufacturing. It is assigned to each handset made and is an unique code.
Mar 15, 2014 | Samsung Galaxy GT-S5570
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
Panasonic kxt7630 button assignment
I've never heard of the ability to reassign an intercom button as it's a fixed feature, but maybe so. Start by assigning the lower left phone button back to CO1 and let's see what happens. WIthout picking up the handset, press PROG the button and dial 0+01 STORE or ENTER.
Pick up the handset and drop it back in the cradle to exit programming.
Did that work? Making button 1 into CO1 will drop the programming from the intercom button and it should default back to intercom.
Carl
Apr 15, 2010 | Panasonic KX-T7630 Corded Phone
Extention Names?
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system -
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 004 and then ENTER.
3. Enter the extension number you want to change.
4. Enter the name (the same way as texting on a cellphone.)
5. To save the changes press AUTO DIAL / STORE.
6. To go to the next extension press NEXT on the screen.
7. Lift the handset and put it down to exit program mode.
Feb 18, 2010 | Panasonic KX-T7630 Corded Phone
Voice dialing on the i870 motorola phone
Using a Voice Name
Follow the prompts of your voice dialing service, first which means that you need to run the set up of this feature. Each number can be assigned a voice dialing option, which the phone must be trained to recognize.
If you have created a voice name in Contacts for the number you want to call, say the voice name into your handset to enter the number.You can use a voice name to enter a handset number
with the flip open or closed.
1. Press and hold t until a prompt appears telling
you to say the voice name.
2. Speaking into the microphone, say the voice name assigned to the number you want to call.
Your handset plays the name back to you.
If you are making a Private call, press and hold the
PTT button to place the call.
If you are making a phone call, the call is placed
automatically.
(Tip: To stop a phone call from being completed,
press . if the flip is closed or press e.)
Mar 17, 2009 | Motorola Mobility i870 Cellular Phone
PANASONIC KX-TDA-50 PHONE SYSTEM WITH KX-T7633 PHONES - HOW DO I CHANGE THE NAME ASSIGNED TO AN EXTENSION?
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
Jan 21, 2009 | Panasonic KX-TDA50 Phone
I just got this phone VTech 5881. I plugged it in and have tried to register the handset. I can't. It has someone else's name in it. what should I do?
First, deregister all handsets:
Step 1: At the base, press MENU, scroll to BASE SETTINGS, then press OK.
Step 2: Using the base dialpad, enter * * 3 3 5 7 8 2
Step 3: Re-register each system handset:
At the base, press MENU, scroll to DISPLAY BASE-ID, then press OK. The 15-digit base ID number will be displayed.
Step 4: Using the handset dialpad, enter the base ID number. Repeat the registration procedure for each system handset. Each handset is assigned a number in the order of registration
Dec 13, 2008 | Lands Phones
For assigning a person name to the extention
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
Jun 18, 2008 | Panasonic KX-T7730 Corded Phone
NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
  1. Press the Speaker key (do not use the handset).
  2. Dial the Name Assignment access code and wait for the special dial tone.
  3. Using the key pad spell the name. Press each number until the letter appears.
  4. When the correct letter is displayed Press the HOLD key. Pressing the HOLD key will lock the letter in place and advance to the next position.
  5. Repeat steps 3 and 4 continue to spell the name.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
Apr 16, 2008 | NEC Dterm DTP-2DT-1 Phone
Samsung d900i
Create contact (Menu 2.3)
Use this menu to add a new contact to Phonebook.
Storing a number in the phone’s memory
1. Select Phone.
2. Change the settings or enter information about the
contact:
First name/Last name: assign a name.
Mobile/Home/Office/Fax/Other: add a
number in any category.
You can change the number type, or set the
number as the default for the contact by
pressing <Options> and selecting Change
type
or Mark as default number.
Email: assign an e-mail address.
Graphic ID: assign a caller ID image to alert
you to a call from the person.
Ringtone: assign a ringtone to alert you to a
Group: assign the number to a caller group.
Birthday: enter the person’s birthday.
Notes: add a memo about the person.
3. Press <Save> or [ ] to save the contact.
Storing a number on the SIM card
1. Select SIM.
2. Select New or Update.
3. Enter information about the contact:
Name: assign a name.
Phone number: add a number.
4. Press <Save> or [ ] to save the contact.
Mar 05, 2008 | Samsung SGH-D900 Cellular Phone
Panasonic KX-T7630 Corded Phone Logo
77 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
