Question about LG Xenon GR500 Cell Phone
The screen wont rotate anymore? - LG Xenon GR500 Cell Phone
Camshaft on a 2004 Suzuki Forenza will not turn anymore can not lining up with the timing marks how can I turn it to make it lines up with the timing mark
Not knowing how far your cam timing is off, your valves may be hitting the top one of a pistons. That may be why cam wont turn anymore.
May be best to back up the cam a bit, remove the spark plugs & with screw driver or wooden dowel probe the cylinders to see which piston is near the top.
Then rotate crank a bit to lower piston down the cylinders DO NOT USE STARTER to rotate engine while timing belt is off or valve damage may occur.
Jul 16, 2016 | Suzuki Cars & Trucks
Camshaft would not turn anymore can't make it to the timing mark how do I turn it to the timing mark
Jul 16, 2016 | Cars & Trucks
My hisense screen wont rotate
Open Quick Settings and tap on Auto Rotate or go to Settings, System, Accessibility, Auto-rotate screen.
Jul 21, 2014 | HQRP AC Power Adapter micro USB Charging...
Sounds and discplay
There is some corruption, I think a factory reset should do the trick.
Apr 26, 2017 | Nextbook Premium 8 Se Android
My zeki tablet wont rotate when you turn it
go to setting>display>rotate screen
check the box(click in box)
it'll activate auto rotate
Jan 29, 2014 | Zeki Berk Ulu 8GB 7in WiFi Android Tablet...
When I rotate phone the picture does not rotate anymore?
In settings there is an option to lock the screen rotation.
May 13, 2012 | Apple MD276LL iPhone 4S 16GB Verizon...
I have a gilmour 193spb polymer impulse sprinkler. It won't rotate anymore by itself. If I turn it to one side it will rotate to the other side, but wont trip to rotate back automatically.
Yea. Join the club. One day you and I both might purchase a better sprinkler. That way it might be worth the cost of a gallon of CLR (calcium/lime/rust remover) to soak them in which should fix the problem.
We could have/should have, but might never blow them out to remove all water remains before storing them for the winter.
:o).
Jun 04, 2011 | Garden
LG Xenon GR500 Cell Phone Logo
16 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
