Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
Cannot add write files to SimpleTech drive from a Mac
Trying to move files off of a Mac computer. They cannot be added to my 60 GB SimpleTech drive, I get error messages saying the "drive cannot be modified".
  • 3 Answers
Most of the times you just have to format the drive to Mac OS Journaled or else you will only be able to transfer 4gb or less at a time.
Posted on Sep 23, 2009
Can i transfer information to a mac
If the external hard drive has been formatted on a PC in NTFS file format then the MAC cannot read data off this hard drive.
The FIX..
Connect the USB external hard drive to a Windows computer and copy your data off this hard drive to the computer.
Then format the external hard drive in FAT32 file format. (the MAC can read and write to data to and from a Windows PC)
Now copy the your data from the computer back onto the external hard drive.
Now you can connect the external hard drive to the MAC and download your data to the MAC.
Feb 22, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
My Lacie isn't letting me move files onto it. I need to move movie files over from my mac to the Lacie, but it's not working. I had added .wav files a few months ago, and those are accessible, but now that...
did you use your drive with a PC too?
What you describe is commonly linked to a drive formatted as NTFS (a windows partition format) which is read only on a plain MAC system. There are add ons you can install on your MAC to make NTFS writable. I can direct you to one if you need.
Another possibility is that your drive is formatted as MS-Dos (FAT32) which is read and write enabled for both PC and MAC, but it has the negative aspect of limiting file size to 4GB. So in your case, maybe your movie files are larger then 4GB and your drive is formatted Fat 32.
To verify the format of the drive, go to DIsk utility, select the LaCie drive and read the information that shows at the bottom of the Disk Utility window.
Regards,
Jan 10, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
My iMac doesn't recognize my simpletech 160gb, but my PC does. Trying to get the hard-drive to work on the iMac.
Most likely it's formatted in NTFS which the Mac supports only with an addon, that you don't have.
The easiest way to fix that is to format the Simpletech in FAT32.
Dec 28, 2010 | SimpleTech SimpleDrive 160 GB External USB...
All my files on simpletech harddrive show as 0
you mean you HDD does not show the capacity it holds? try using it on another pc, or even try using it on your friends pc, see if it works?
Mar 28, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Simpletech 60GB hard drive is not recognised by my computer.
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Jun 24, 2009 | SimpleTech (STC-M700HD/60) 60 GB Hard...
I have a 60 GB simpletech external hard drive. I
Try to hook it up to another computer and see if it works there. This will tell you if the device is failing. If you have found that it failed please see about replacing the power adapter. If still no live the device has failed and needs replacement.
Thanks, Frank Z.
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 24, 2009 | SimpleTech Pininfarina 60GB External USB...
No Write permission when attaching Simpletech external drive to Mac OS 10
simple just format it for PC first then it should work for both
if you format it for MAC first it will not work on the PC
simple
PC are horrible for accessing files
mac's are more user friendly
Jul 02, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 320 GB
my advice to you is open it and unplug the one touch button.
Jan 11, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Restoring backup files
well first off you should not use teh same external hard drive for both dell and mac! and for it to work on a dell you need to go to disc utility in the applications folder and click on you external hard drive and go to the last pannel which is called restore and put in the given info and it shall work!
Jan 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Can not modify
Make sure both plugs are connected to USB ports, the closest plug is for data transfer and the send plug is for additional power to run the drive. The shorter the cabe the better.
LOL
Jan 01, 2008 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
Computers & Internet Logo
602 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
