Question about Kyocera Slider Cellular Phone
When i turn on the screen blinks hello over and
When i turn on the phone the screen blinks hello over and over and wont do anything else. It also will not turn off. I took the battery out and put it back in and it just starts blinking "hello" over and over.
I have turned it off and on and it wont let me do anything else
Write your answer...reset your phone . just it
Dec 03, 2015 | Cell Phones
My nokia 7710 screen keeps on blinking (it looks ...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
May 20, 2010 | Cell Phones
I droped it and the screen wont turn on
Since you said the phone drop from you, it is possible that the screws that attach the screen of your phone is not tight anymore.
I suggest you get a torx6 screw driver, power off the phone, remove the battery and turn the the phone over.
Carefully remove the front cover of your phone that leads you to your phone screen.
Use the torx6 screw driver to tighten all the screws of your screen very well to the panel of of your phone.
Recouple your phone back, put the battery and power on, the screen should display.
But if the screen did not display, it means the flex on your phone is bad and will need to be replaced.,
So change the flex if tightening of the screen did not work, so change the flex on your phone and your phone will display.
Take care.
May 08, 2010 | Sony Ericsson T715 Cell Phone
Sony ericsson w810i phone wont come back on after being turned off. It just blinks with a blank screen.
mobruadair hello,
Please remove the back cover of your phone, remove the battery and the SIM card.
Then, after a few seconds, put everything back in and make sure the contacts are okay and that everything is steadily in place. Try turning the phone on now, and see what happens.
Oct 25, 2008 | Cell Phones
Phone blinks white and wont respond.
sometimes when you turn the phone off, take out the battery, put the battery back in, then turn the phone back on, it fixes the problem... sometimes it doesn't though
Dec 21, 2007 | Motorola Mobility RAZR V3
Screen died, now Phone Wont Respond to Anything
you need to take the phone to a mobile service center and have them revive the phone for you.
Aug 27, 2007 | Motorola Mobility RAZR V3
Blank white screen, then off after 10 sec.
Try using a different battery. If that doesn't work, phone's IC must be damaged. Get the phone checked from a Nokia service centre.
Mar 22, 2007 | Nokia 3230
Kyocera Slider Cellular Phone Logo
115 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
