Question about Frigidaire Dryers
My Frigidaire Affinity dryer stopped working after less than 2 years. No lights, nothing. I checked our fuse box and everything is fine. Is there a fuse in the dryer that needs to be replaced or reset?
  • 1,531 Answers
There is a couple of thermal fuses that you can check inside the dryer chances are it is the one that is located one the back wall behind the drum
Posted on Sep 27, 2009
My affinity front load washing machine will not start, there are no lights - nothing. The stackable dryer on top does start. Is there some kind of re start button for the washing machine
To Stranded,
Here is a link that will put you directly to free support and a manual to guide through the trouble shooting function. sparke needs help with Frigidaire Washer on ManualsOnline com . If you are familiar with a meter to troubleshoot and identify voltages. Start there. If the display is functional. Here is another forum you can tap for resources to compare. Basics first. How to enter diagnostic mode on Frigidaire ATF7000 washer Appliance... .
And you will need to take it apart.. here is the link for that solution.
Frigidaire Affinity Washer Disassembly
Say how you made out and if this approach helped please?
Fare. Well.
Sep 19, 2014 | Frigidaire Affinity ATF7000E Front Load...
Dryer won't turn on
There should be a small fuse in the circuit in the rear of the dryer.
Mar 16, 2014 | Frigidaire Affinity 7.0 cu. ft. Ready...
Frigidaire dryer dries for a few seconds then stops and lights blink.
Hi laylabetes - Answering your question, there isn't a way to actually CLEAN the control panel. Depending on an actual diagnose from a professional, the part would need replacing or if possible repair. However, if your model is electric, turns and there is no heat, it could possibly be a blown fuse. There are two house fuses that supply voltage to your dryer circuit in your fuse box. If one of the two is blown, the dryer may turn but will not heat. Check and replace fuse in fuse box if necessary. Please feel free to reconnect if this does not resolve your issue - Best, Chris
Jul 01, 2013 | Frigidaire Dryers
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Affinity dryer burning clothes
Probably a seal around the drum or blower needs to be replaced.
Affinity service manual
Nov 24, 2012 | Frigidaire Affinity FAQG7011KW 7.0 Cu. Ft....
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
Sep 26, 2009 | Frigidaire Electric Dryer
Frigidaire Affinity Dryer
try hitting stop clear twice check the door switch see if its working also if you didnt send in your warrenty card then frigidaire dont know when you bought it if youve never had it serviced i was a factory tech for years for frigidaire so you can call them and say you bought it say a week from now and get it serviced let me know what happens
May 17, 2008 | Dryers
Dryers Logo
237 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
