Question about Hampton Bay 24750 Huntington III Ceiling Fan
Ceiling fan I can not get it to go in reverse. There is no switch just a remote... WHY???
  • Anonymous May 04, 2009
    I have no reverse on remote and I don't find one on housing ,now what?
    no reverse on remote for hampton bay fan. can't find on housing
It is not always located on the housing. Our remote has a reverse button but it is no longer working. Oh, and they don't sell remotes w/ a reverse switch. Thanks, Hampton Bay, for nothing.
Posted on Aug 15, 2008
The reverse switch is always located on the fan housing itself.  You cannot reverse using the remote.  Look for a black slide switch, probably located on the top surface of the fan housing so you cannot see it easily without a ladder.
Posted on Jan 07, 2008
SOURCE: Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Posted on Sep 05, 2007
SOURCE: HOW DO make the HAMPTON BAY UC7083T CEILING FAN go
you need a hamton bay remote with a reverse button on it. make sure dip switches are same as other remote.
Posted on Aug 05, 2009
SOURCE: Installing ceiling fan with two switches AND a remote
I have a hampton bay ceiling fan with light fixture all connected to a wall switch and controled by a remote. The light does not work any more and I have replaced the bulb with three different light bulbs and it still won't work. There is a green wire coming off the bracket but there is no ground wire coming in from above. There are two wires coming in from above ( the box in the Attic)
one white and one black and they are connected properly. All the wires are taged from the remote receiver, the fan and the light and are correctly connected. Any suggestions?
Posted on Mar 30, 2008
SOURCE: Remote control ceiling fan
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
Posted on Apr 12, 2008
  • 4 Answers
SOURCE: my ceiling fan has no reverse switch, how do i
My fan does not have a reverse switch for sure so I scoured the net and got no real answer. I did come accross a comment that said that it worked internally at the remote box in ceiling. Here is how I finally figured it out after about 6 months of searching. Put the fan on high, Turn wall switch OFF, Hold the HI button on remote, Turn switch back on. IT WORKS!!!!!!!!!!!!! Sparq
Posted on Sep 24, 2009
How to manually reverse ceiling fan direction.
You did not provide a make or model of your fan, but check your owner's manual if you have one. There should be a website or a service support telephone number to obtain more information. Most ceiling fans have a reversing switch on the fan itself. They can be a pull-chain type or a slide switch.
Jul 25, 2015 | Dryers
Where to buy a universal remote for Hampton Bay ceiling fan w/reverse that's 6 Years old fan?
You can use a remote from Home Depot, where the fan was bought. Reverse will have to be done manually at fan.
Aug 29, 2014 | Hampton Bay 24002 Ceiling Fan
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
How can i switch my fan to reverse? Its a Hampton
There is usually a slide switch on the side below the motor.
I don't believe any of them reverse from the remote control.
Nov 26, 2009 | Hunter 52" Ceiling Fan With Light And...
How do I reverse my ceiling fan using a remote?
there will be a small black switch on the motor change postion of switch it will reverse fan
Sep 05, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay ceiling fan - will not reverse
It sounds like the direction switch has a broken connection on the "reverse" side.  Should be an easy fix (but you might need a soldering iron).
Dec 07, 2008 | Kitchen Appliances - Others
Reversing direction on remote controlled fan
There is no switch. Put the fan on high then hit the reverse button. Your fan should stop, reverse and you'll bet all set.
Nov 20, 2008 | Hampton Bay 52 In. White Redington...
Concept II
Depending on what year the fan was made try looking very close at the actual body of the fan. you may find a small switch you can manually use to reverse the direction of the blades.. I may have some used working remotes that will work with your fan if you like please feel free to contact me at payitforwardx2 @ gmail . com .
Jun 08, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Hampton Bay 24750 Huntington III Ceiling Fan Logo
701 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
