Question about Refrigerators
I WAS ON YESTERDAY WITH THE SAME APPLIANCE A JENN AIR REFRIGERATOR JCD2389GEB. I NEED TO START AT THE BEGINNING. EVERY COUPLE OF WEEKS MY REFRIGERATOR ON TH ICE BOX SIDE WOULD GET WARM THE FREEZER WAS COLD AND ICE WOULD BUILD UP ON THE COILS, SO I WOULD DEFROST IT WITH MY HAIR DRYER. THAT WOULD LAST ABOUT THREE WEEKS. OUR FRIEND WHO DOES SOME WORK ON A/C AND APPLIANCES SAID IT WAS LOW ON FREON SO HE ADDED IT LAST WEEK. EVER SINCE THEN OUR ICE MAKER HAS NOT MADE ICE, THERE IS KNOW WATER. HE SAID HE HAD POWER TO THE ICE MAKER BUT KNOW POWER BACK TO THE SOLENOID. WE HAVE WATER TO THE WATER DISPENSER.HE ALSO ADDED FREON LAST NIGHT BECAUSE MY FREEZER WAS AT 30 DEGREES. I CAME HOME TODAY AND THE FREEZER DOES NOT FEEL VERY COLD. THE FEW THING IS HAD IN THERE THAWED OUT, I ALSO CHECKED THE COILS AND THEY A SWEATING AND WATER WAS IN THE BOTTOM OF THE FREEZER. I NEED TO KNOW WHAT THE PERFERED SUCTION PRESSURE IS WHEN THE FREEZER IS 30 DEGREES AND WARMER. HELP!!!!!!!!!!!!!! I ALSO ORDERED A NEW ICE MAKER BUT I READ THE FREEZER HAS TO BE AT LEAST 12 DEGREES FOR THE ICE MAKER TO WORK.
  • 220 Answers
What you started out with was a defrost issue,adding freon made your problem worse,pressure on the low side when fully charged should be around 0 to 3 lbs.
 the most common problem with theses units is the adaptive defrost control sits in the refrigerator section top right corner above the white plastic cover.part # 61005988 runs about $70.
 Second most common defrost issue is the defrost thermostat # 61006199 runs around $45 comes wired in with the heater assy sits behind the wall in the back of the freezer. But first you need to get someone to evacuate the system and put in the right charge it will be on the model number tag on the ceiling of the fridge it's somewhere between 4 and 6 onces not pounds.
Posted on Sep 24, 2009
I have a Jenn Air side by side and the drain at the bottom of the freezer side keeps freezing up and the water ends up draining out the door onto my floor. I defrost the drain and it's ok for a couple...
You are going to have to get the drain good and clean. Take a turkey baser and force hot water down the drain until water flows freely. Once water is flowing freely mix water and baking soda and pour it down the drain. I hope this helps.
http://www.appliance-repair-it.com/Refrigerator-repair.html
Oct 21, 2010 | Jenn-Air JCD2389G Side by Side...
Problem with the water dispenser in the Jenn Air Refrigerator
Did you find a solutioin to this problem? I have the same exact one?? Thanks
May 29, 2010 | Jenn-Air JFC2089HE French Door...
JCD2290HES Side by Side Refrigerator: my jenn air side by side is freezing everything an...
i have the same problem i clean the coils and work for two weeks and now is freezing need solution thanks
May 16, 2010 | Jenn-Air JCD2290HES Side by Side...
Water is leaking underneath the freezer side. Not continually, but couple days a week. I have newspaper under it now.
Clean the drain pan and drain line in the back of the freezer section behind the back cover and underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | Jenn-Air JCD2389G Side by Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389GEB - Water dispenser
Our water line looks to be abut vertical...
Jul 23, 2008 | Jenn-Air JSD2789GEB Side by Side...
Jenn-Air Refrigerator JCB2059GES freezes
your thermostat is bad,get the model number from inside and call your local appliance store and get a new one,let me know,thanks-mike
Jun 23, 2008 | Jenn-Air JCB2059G Bottom Freezer...
Jenn-Air JCD2389GEB side by side
the clicking noise is the motor overload. have a service tech check for a freon leak.
Sep 24, 2007 | Jenn-Air JCD2295HES Side by Side...
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
