Question about Thermador (HDI54TS) Stainless Steel Kitchen Hood
When my thermador HDI 42 hood was installed in 2004, the installers did not install tne plastic transition with back draft dampers. How and where do I install it?
  • Thermador Master
  • 8,220 Answers
A transition is a filler between the hood and wall to join the two smoothly. It probably was not needed. The dampers Mount above the blower. I don't know if this manual will help you. Hell it might be worth the 3 bucks anyway.I have a bunch of them.
Posted on Sep 24, 2009
Fl3 code. heater working fine when i closed last year. will not start this year. showing fl 3- does not ignite , does not do anything ..help please
3.
Spillage at A.Cold chimney A.Allow heater to operate 5 minutes to create draft action.
draft hood B. Vent pipe pitches down to chimney B. Reinstall vent pipe to pitch up from heater to chimney.
C. Blocked chimney C. Remove blockage.
D. Draft hood altered D. Install factory-provided draft hood.
E. Prefabricated chimney with incorrect cap E. Install a Nationally Recognized Testing Lab (NRTL) listed vent
http://www.jandy-downloads.com/pdfs/Lite2_LJ_IO_H0248900F.pdf
I tried to copy the FL3 write up from the chart but it screwed it up a little. Look at Page 35 of the manual for a clear copy
Jun 10, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
In winter, cold air blows back down and out through the fan.
Either a backdraft damper was never installed in the ductwork or the damper is stuck open...
Has it always been this way?? If so then the damper probably was never installed and you will need to have one installed to stop the air...
If it was good at the beginning and now is not then the damper is stuck open...you will need to find it and then get it working agian...
The dampers often are right at the outlet of the hood...if you take down the hood it should be right there...
heatman101
Feb 11, 2011 | Broan-NuTone Best By Broan EB12 External...
Change back struts
Please don't forget to rate! Thanks!
Removal & Installation
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Raise and support the vehicle safely. Remove the rear tires.
  3. Remove the flange bolt from the bottom of the damper.
  4. Remove the flange nuts from the bottom of the damper.
  5. Open the trunk and remove the access panel cover, if necessary.
  6. Remove the flange nuts from the top of the damper
  7. Remove the damper assembly from the vehicle.
Exploded view of the rear suspension strut-2001-05 Civic
To install:
  1. Position the damper assembly in the vehicle.
    NOTE
    Be aware of the direction of the damper mounting base so that the small hole dot on it is toward the front inside of the vehicle,
  2. Loosely install the flange nuts on the top of the damper.
  3. Loosely install the flange bolt on the bottom of the damper.
  4. Raise the suspension with a floor jack to load it with the vehicles weight before tightening the nuts and bolt.
  5. Continue the installation in the reverse order of the removal procedure.
If it's hard to see the diagram please post your email and I'll send it to you.
Sep 15, 2010 | 2004 Honda Civic
Cold air from outside enters the kitchen through the down draft vent.
its would be best to install a damper
whether auto matic
or manuely operated
this is a common problem for the down draft
ive seen some people install things similar
to dryer vent louvers,
but check you exhaust area and still if you can block direct draft
but dont block it so that it cannot exhaust properly
Oct 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Range hood installation
you can reseal the hole with aluminium tape
you can use screws with metal flat washer that has a rubber backing
May 28, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Range vent damper noise
Check to make sure that the installer completely untaped the damper when he installed it. It needs to be able to move freely.
Apr 04, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Power vent tankless heater has a down draft
I got a dryer vent kit (Alum) took the extension pipe off and cut the center hole open a little and slid it over the existing elbow. Now when the heater turns on the little flap opens and when the air flow stops the flap closes stopping the air coming down the pipe.
Jan 16, 2009 | Rheem Tankless Hot Water Heater...
Can fan be lower when operating at full speed
Improper air flow was also my problem. The contractor did a terrible installation job. The duct work was incomplete at the transition piece (he used the under cabinet space as part of the duct) and did not seal the duct to the fan assembly. Both items were not readily visible. Once the duct was correctly installed, the unit works fine. Remember a down draft is never as good as an overhead vent.
Jan 02, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador cook top with down draft ventalation
I would think you can. Most of the cooktops are 240v and the vents are 120v, so the vent may be feeding off of one of the cooktop's hot wires. My vent is fed from it's own receptacle but is harnessed along with the cooktop's 240v.
Oct 31, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Wind comes through island hood
Thee is supposed to be a damper in the vent pipe were it connects to the hood. maybe its missing or stuck.
Nov 02, 2007 | Kitchen Ranges
Thermador (HDI54TS) Stainless Steel Kitchen Hood Logo
62 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
