Question about RTO Bernzomatic Brushed Nickel Patio Heater
Bernzomatic patio heater keeping going out, first time ran for 13 mins, relit, ran 7 mins, relit ran 5 mins.. u see the pattern
5 Suggested Answers
SOURCE: I need a control stem for a bernzomatic patio
I HAVE A CONTROL STEM FOR A BERNZOMATIC MODEL #3250
USED $50.00 US CALL 1-262-375-7091 ASK FOR RICK
Posted on Nov 28, 2009
  • 6 Answers
SOURCE: i have a bernzomatic patio heater. i can get the
See my reply on this other post. http://www.fixya.com/support/t3536737-trying_ignite_heater_but_will
Posted on Dec 15, 2009
fkuk
  • 311 Answers
SOURCE: Need to replace a control knob on bernzomatic
what you could do is have like a lever valve (like the ones on garden hoses but for gas systems)
and then have the burner on full blast but you control the amount of gas going in
Posted on Jan 15, 2010
  • 4 Answers
SOURCE: The bernzomatic patio heater will
More than likely it is a bad thermocoupler. The thermocoupler is that pointed piece that receives the shock when pressing the ignite knob. You will have to take the unit apart to get to it. It is the pointed part with stiff wire attached that is between the shock electrode and the pilot light. It could also be the magnetic valve at the base of your control knob, but I doubt it. It could also be the tip switch which you can test with a simple continuity bulb or tester. The tip switch is wired inline between the thermocoupler and the control valve and knob assembly. It is about nickle size and has 2 wires attached to it. You can test the magnetic valve by removing it from bottom or base of the control knob and touch one end of it on a AA battery and the other end of it jumper to the opposite end of the same battery while depressing the spring at the same time. If the magnetic switch is working you will feel the magnets attract until you pull the battery or jumper wire away disrupting the connection. There is also a way to measure the resistance of the thermocouple but if you have tested the other two items you can bank that the thermocoupler is bad. Before and after make sure you don't have any leaks by using a soapy water in a spray bottle at all of the gas connections as per the owners manual.
Posted on Feb 01, 2011
What is the part number for the control knob for the Bernzomatic Patio Heater model # PH3250N?
Bernzomatic does not provide nor sell replacement parts for their products - they consider them disposable.
If the plastic knob is the only piece you need, Amazon sells a few replacement knobs for patio heaters. I searched Amazon with the terms:
replacement knob patio heater
Nov 01, 2017 | Pool & Spa
Bernzomatic patio heater will not light?
these had problems with purging air out of the system.that may take a while and make sure you have spark.
May 01, 2012 | RTO Bernzomatic Brushed Nickel Patio...
I have a bernzomatic 94499 patio heater does anyone know where I can find an owners manual? The pilot will light but not the burner? There is a brass fitting towards the back that seems to be the burner...
You need to replace that brass piece . Its a thermocouple. Bernzomatic does not sell a replacement thermocouple, however I had success using Mr. Heater 12.5" replacement thermocouple. You can buy it from Ace hardware. Its also sold on Amazon.
http://www.amazon.com/Mr-Heater-12-5-Thermocouple-Heaters/dp/B000BP7LJ2/ref=sr_1_1?ie=UTF8&qid=1325746531&sr=8-1
To remove the nut on the old thermocouple I use a 13/32" socket. I think a 10mm would work also. Must be a deepwell socket. The new Mr. Heater nut takes a 7/16" socket. The old thermocouple runs to a black plastic piece with soldered on connectors. I removed this piece entirely. The electric igniter's ground wire runs to one of the bolts, so that must be put back after the piece has been removed. I did make the effort put the white cloth cover over the new thermocouple. I took it off the old one. I barely fits over the nut, and must be worked on like a Chinese finger trap but it will go. Good luck.
Sep 07, 2011 | RTO Bernzomatic Brushed Nickel Patio...
Need Bernzomatic Heater Knob
most universal kitchen, bbq,small appliance replacement knobs will fit ur application
Mar 03, 2010 | RTO Bernzomatic Brushed Nickel Patio...
Need to replace a control knob on bernzomatic patio heater, where would I get one? Called the company and they said they don't make them anymore.
Jan 15, 2010 | RTO Bernzomatic Brushed Nickel Patio...
RTO Bernzomatic Brushed Nickel Patio Heater Logo
512 people viewed this question
Top RTO Pool & Spa Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
