Question about HP Photosmart 2610 All-In-One InkJet Printer
All the lights just flash error code0x886a6b72
It started when itried t cancell a fax that i was sending to the wrong number. after it is turned on and before lights start to flash tou hear the clicking like a phone
  • 3,153 Answers
Microsoft has the help you need for this issue and I wont try to give you long and possibly misleading information on here.
It is a common problem but the answer is here
http://support.microsoft.com/kb/946737
You need to refer to method "D" about half way down the page
Once you clear the print job check you dont have any extra printers installed as quite often happens in these situations. If you have then delete your extra printer installations.
Posted on Sep 24, 2009
  • 615 Answers
Go to your print file and delete all pending jobs do that for all of them if yo have more than one...then go to device manager and see if yo have any red or yellow error if not that is good, reboot your printer and shutdown not by ctrl+alt+delete but totally shutdown and restart again...if that work that is great if not you may need to reinstall the program again as you may have corrupt file. remmber when you install or delete anything on your computer you need to restart the system for the changes to take effects...let me know if that work and please remmber to rate my service so I am able to contenue provide quality service and improve on it with your help. God bless
Posted on Sep 23, 2009
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Error light is flashing, can't figure out why, no code
I know this was posted a long time ago but for what it's worth. The error codes are probably turned off. I can tell you how to turn on the error codes if this is still a problem. please let me know.
Dec 05, 2013 | Canon LaserCLASS Fax 710 Printer
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
Reception error need code to get fax out of memory, keep putting in yellow cartridge and says it want yellow
To send or cancel a fax in memory, do the following:
  1. Press Menu/Set, 2, 6.
  2. Using the up/dwn arrows, select the job you wish to either send or cancel
  3. Once your fax appears in the LCD window, Press 1 to cancel the fax or Press BLACK/START to send the fax
Hope this solves your problem. Best of luck!
Greg
Nov 12, 2009 | Brother IntelliFAX 1840C Plain Paper...
Tx Cancelled: Rx Fax Info Mismatch
Can you tell me how you resolved it? Please Email me at:
PalpatineX@comcast.net
Sep 24, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
ELTRON 2622 thinking it's a fax
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default and dumped whatever setting told it to act as a fax.
Aug 07, 2009 | Zebra ELTRON 2622 TT Printer
Fax error message = TX cancelled:RX fax info mismatch???? Cannot send fax - How do I fix this error - Not all faxes return this message
Two Issues:
1. The Transmission Speed of the MX860 may be too fast.
Solution: on FAX Menu go to Settings>Device Settings>FAX Settings>Transmission Settings >"TX start speed" and change to 14400 or lower (14400 worked for me).
2. The recipient FAX machine may be receiving by a different number than the one you dial. This may occur if you dial a free-calling no.
Solution: Go to Transmission Settings as above>"Check RX fax info" and turn it to OFF. This disables the mismatch issue.
Hope this helps. aknz
Jul 31, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I HAVE A PANASONIC FAX kx-FPG376 IT WONT SEND FAX MAKES COPIES AND RECIEVES FAXES
I dont know how we got disconnected but here is the instructions
Adjust the width of the document guides (1)
to fit the actual size of the document.
2 Insert the document (up to 10 pages) FACE
DOWN (2) until a single beep is heard and
the unit grasps the document.
L If the document guides are not adjusted
to fit the document, re-adjust them.
3 If necessary, press {A} or {B} repeatedly to
select the desired resolution.
4 Press {DIGITAL SP-PHONE}.
5 Dial the fax number.
6 When a fax tone is heard:
Press {FAX/START}.
When the other party answers your call:
Ask them to press their start button. When
the fax tone is heard, press {FAX/START
To redial the last number
1. Press {REDIAL/PAUSE}.
2. Press {SET}.
L If the line is busy, the unit will automatically
redial the number up to 2 times.
L To cancel redialing, press {STOP}.
To send more than 10 pages at a time
Insert the first 10 pages of the document. Add
the other pages (up to 10 at a time) before the
last page feeds into the unit.
Pre-dialing a fax number
You can dial the fax number first before inserting
the document. This is convenient if you need to
refer to the document for the other party’s fax
number.
1. Enter the fax number.
2. Insert the document.
3. Press {FAX/START}.
Sending from memory (Quick scan feature)
You can scan the document into memory before
sending it. To use this feature, activate feature
#34 (page 62).
1. Insert the document.
2. Enter the fax number.
L The document will be fed into the unit and
scanned into memory. The unit will then
transmit the data. If the document exceeds
the memory capacity, transmission will be
canceled and this feature will be turned OFF
automatically. You must transmit the entire
document manually.
L This feature cannot be used if {DIGITAL SPPHONE},
{TALK} or {SP-PHONE} is
pressed.
To stop transmission
Press {STOP}.
Aug 27, 2008 | Panasonic Office Equipment & Supplies
Sending fax error message "low memory"
Try reading these:
General fax problems
Issue Cause Solution The document stops feeding in the middle of faxing. The maximum length of a page that can be loaded is 381 mm (15 inches). Faxing of a longer page stops at 381 mm (15 inches). If no jam exists and less than one minute has elapsed, wait a moment before press Cancel . If a jam exists, remove the media. If the item is too small, it can jam inside the automatic document feeder (ADF).
(HP LaserJet 3015 all-in-one) The minimum paper size for the ADF is 74 x 105 mm (2.9 x 4 inches).
(HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one) The minimum page size for the ADF is 127 x 127 mm (5 x 5 inches). If a jam exists, remove the media. The fax activity logs or fax call reports are printing at inappropriate times. The fax activity log or fax call reports settings are not correct. Print a configuration report and check when the reports print. Set the appropriate log or report printing times through the control panel or the HP Toolbox. The volume for sounds that the device emits is too loud or too soft. The volume setting needs to be adjusted. Set the appropriate sound volume settings through the control panel. Fax send troubleshooting Use the information in the following table to solve problems that might occur when sending faxes: Issue Cause Solution Faxes stop during sending. The fax machine to which the fax is being sent might be malfunctioning. Try sending to another fax machine. The telephone might not be working. Do one of the following:
  • Turn up the volume on the device, and then press Fax/Send on the control panel. If a dial tone is heard, the telephone line is working.
  • Disconnect the device from the jack in the wall, and then connect a telephone to the jack. Try to make a telephone call to make sure that the telephone line is working.
A communication error might be interrupting the fax job. Change the redial-on-communication-error setting to On.
See the electronic User Guide on the CD-ROM that shipped with the product. The device is receiving faxes but is not sending them. If the device is on a PBX system, the PBX system might be generating a dial tone that the device cannot detect. Disable the detect-dial-tone setting.
See the electronic User Guide on the CD-ROM that shipped with the product. A poor telephone connection might exist. Try again later. The fax machine to which the unit is sending to might be malfunctioning. Try sending to another fax machine. The telephone line might not be working. Do one of the following:
Outgoing fax calls continue to be dialed. The device automatically redials a fax number if the redial options are set to On. Press Cancel to stop the redials while the device is dialing.
To cancel a pending fax job, see "Canceling a fax job" in the electronic Users' Guide on the product CD-ROM.
See "Changing the redial settings" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent are not arriving at the receiving fax machine. The receiving fax machine might be off or might have an error condition, such as being out of paper. Call the recipient to make sure that the fax machine is on and ready to receive faxes. The originals might be incorrectly loaded. Make sure that the original documents are correctly loaded into the automatic document feeder (ADF) input tray or flatbed scanner (not available with the HP LaserJet 3015 all-in-one). A fax might be in memory because it is waiting to redial a busy number, other jobs that are ahead of it are waiting to be sent, or the fax is set up for a delayed send. If a fax job is in memory for any of these reasons, an entry for the job appears in the fax log. Print a fax activity log and check the Status column for jobs that show a Pending designation. All of the numbers of a long fax number cannot be dialed. The maximum number of digits of characters that can be entered into a fax number is 50. Try manually dialing the fax number. Faxes that are sent include a block of gray shading at the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent have data missing from the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM.
Jul 16, 2008 | HP LaserJet 3030 All-In-One Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
46 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
