Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
When I turn the key, the selonoid clicks, but the started does not turn. If I short out the 2 selonoid terminals, the engine will turn over. Is the selonoid bad or perhaps the starting switch?
4 Suggested Answers
GM Elec
  • 1000 Answers
SOURCE: difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Posted on Aug 21, 2009
budgie140
  • 501 Answers
SOURCE: won't start
battery flat.disconnect and put on charge
Posted on Jul 07, 2010
ftw1952
  • 10319 Answers
SOURCE: I have a poulan pr185H42ST mower will not start
the two wires to the seat switch can be splice together to operate
If the solenoid clicks that means the seat switch is in good shape
The solenoid must lick loudly pushing the starter drive gear outward to the flywheel to mesh with it. When that happens the starter will turn over the engine
I think your starter is at fault. Inside the starter is magnets for fields for the armature. These magnets are epoxied onto the starters frame housing. If they come off which they do it will lock up the starter which makes it unusuaeble. A replacement starter is what you need if this is the case
Posted on Jul 09, 2011
2003 ford e250. Won't start turn key and just clicks 2 times and then everything shuts off. I have replaced ignition switch and lock cylinder and still doesn't start
Testing the electrical circuit's is the best way to find the problem ! Voltage drop testing ! Reading factory sevice info. learning how to trouble shoot the problem , not replacing parts .Do you know what a wiring diagram is ? How to use one to find point's in an electrical circuit to test at ? Here is a web site for free wiring diagrams . http://www.bbbind.com/free_tsb.html Enter vehicle info. year ,make , model and engine size . Under system click on engine ,then starting in subsystem . Click search button , then the blue link . There is the transmission range switch , the starter relay etc.. you have connection problems or the main battery cable to the starter.
Starter Voltage Drop
How to voltage drop test starter motor circuit
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
watch these videos , buy a volt meter an test the electrical circuits .
Do you know what the relay switch is ?
The starter motor solenoid relay switch:
  • controls current to the starter solenoid.
  • is engaged by the ignition switch.
  • connects the battery (10655) to the starter motor.
The TR sensor on automatic transmission-equipped vehicles prevents starter motor engagement unless the transmission is in the NEUTRAL or PARK position. For additional information, refer to Section 307-01A or Section 307-01B .
Jun 23, 2017 | Ford Cars & Trucks
Engine turns but does not start
you will need to replace either the ignition barrel or the starter motor
Aug 24, 2008 | 1996 Ford F150 Regular Cab
Engine lights on will not start
locate the starter selonoid. with the key OFF, use a remote starter switch or a screwdriver and short the battery terminal to the start terminal (smallest cinnector with a wire that comes from the ignition switch. The engine should turn over- but not start. After you have learned how to do the, try it with the ignition key on. The engine should start. If so, then the "start" contact on your key switch is not making connection. Troubleshoot wire and then keyswitch itself.
Mar 27, 2014 | Gaskets for Mitsubishi 3000GT
Wont start with the key
If you are saying you have a good battery and get nothing no clicks try this turn the key to the on position and using a screw driver,heavy wire or jumper cable.. cross the two post on the selonoid,If it clicks and turns the starter it is the selonoid or the switch not making contact in the start position...most likely the selonoid..good luck..
Feb 11, 2014 | Briggs & Stratton Garden
Hi, bought my son a kazuma meerkat quad 50cc 2010 model electric start, unable to start the quad with the electric start? when ignition on & start button pressed selonoid clicks once & a sometimes...
I had the same problem. My positive wire would arc with the key off when connecting the battery showing a short somewhere. I disconnected the regulator/ rectifier, (where the #16 positive lead from the battery goes to), and it quit. I found a new one on e-bay for $9.90 after shipping and it corrected the problem. Check to make sure your positive is not arcing with the key off. Hope this helps.
Dec 15, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Car won't start. its got a hot battery. Turn key, dash lights up but does nothing,not even click. got under car to ckeck starter used screwdriver on selonoid and it turned over fine. turn key switch...
If your car rolls over when you short the selonoid then the possibilities are limited.
The most likely is your neutral safety switch
the others are the ignition switch or damaged wiring.
Jun 11, 2010 | 2002 Pontiac Grand Am
Suzuki Bandit 400 not starting
The starter motor could be the culprit, check the starter motor.
Apr 15, 2009 | 1993 Suzuki GSF 400 Bandit
Starter won't turn over,I shorted selenoid with screwdriver and it kicked in selenoid and started,,ok bad selonoid,,I just replaced with new starter and selonoid,,still won't kick seloniod in,,shorting...
That wire may be coming from a relay so you may need a service manual to find which one it is.
BTW, to save frying all of your screwdrivers, applying 12 volts for a moment to the terminal with the smaller gauge wire will cause the solenoid to operate as it was designed. Shorting across the main solenoid terminals lets ~ 100-200 amps flow through your screwdriver which isn't even a very good conductor.
Even a light clip lead to the coil terminal of the solenoid could handle the lower current that flows there.
For purposes of doing several different engine tasks, I made up a momentary pushbutton switch contraption housed in a plastic film canister, put 6' wires and heavy clips on it so I could 'jiggle' an engine into the next cycle.
Oct 12, 2008 | Buick Skylark Cars & Trucks
Will not start
Check all of the battery terminals and cables and check the wires on the starter/selonoid, start from the battery and follow the cable out and check all conections , clean and tighten them and if it still does it the starter/selonoid is bad and needs replacement...
thanks
Sep 16, 2008 | 2005 Mazda 3
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
75 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
