Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Water dispenser and ice maker don't work
I replaced the water inlet valve and still does not work. I get little water to the dispenser, no water to the ice maker. I checked the line and i have water but the water does not go up from the solenoid to the ice maker. I also removed the water filter and activated the dispenser without the water filter and alot of water came out of the water filter housing. I have eliminate the tubing which is not plugged, plenty of water, ice maker tube is not frozen, and i hear the solenoid activate when i press the water dispenser. Please, help! I know i can fix it.
  • 221 Answers
You have a bad water filter housing. Be sure to turn of the water to the refrigerator before replacing this part. Replace the filter at the same time.
Posted on May 02, 2017
  • 8 Answers
SOURCE: whirlpool ED5LHAXMB11 Refrigerator side by side
check your module itself on the ice maker make sure the plactic piece that turn the motor is not broke off if you can move the injector blades up and down without force that could be your issue to check you ice make sensor open the freezer and push the light switch 3 times you should get a solid red light where you can turn your ice maker on or off if that is not solid it is the computer chips that are in the freezer liner if all that checks then replace the water valve
Posted on Mar 22, 2008
  • 145 Answers
SOURCE: Ice maker won't make ice
It sounds like the fill tube coming through the freezer wall is frozen shut. Need to carefully take a hair dryer to it then recheck with wire swap. If you turn i/m off for a couple hours then back on you should be able to watch the fingers go around. If so you module should be good.
Posted on Apr 23, 2008
  • 82 Answers
SOURCE: ice maker stopped working
Hello pryorjonw. You may need a new dual water valve, because the part going to the icemaker may be bad, the ice sensing arm may be in the up/off position, the ice bucket may not be positioned properly not triggering the icebucket sensing switch, the condenser coil might be dirty, or the freezer may not be freezing enough to make ice while everything else seems to be staying frozen. To see if your freezer is cold enough, squeeze your icecream carton, as that is the first to thaw if there is a problem.
Posted on Dec 01, 2008
SOURCE: water dispenser tubing in fridge has calcium deposits how to clea
Replace the tubing.
Posted on Mar 19, 2009
  • 351 Answers
SOURCE: problems after replacinf waer inlet valve...
yea that is common just switch the wires and then try to get water out the door.. no biggie you wont hurt nothing... the water just wont come out the same place...
Posted on Apr 30, 2009
Samsung side by side ice maker not working
You have 2 separate valves, 1 for the water dispenser and 1 for the ice maker. (otherwise your ice maker would overflow every time you got water from the dispenser and your dispenser would flow every time the ice maker went to refill.) They are fed from the same tubing.
The cube/crushed ice motor is completely separate from the ice maker itself and should have absolutely no bearing on the water flow.
You have narrowed down the problem quite nicely to the ice maker water valve. There is one more thing to check though, the connector. There should be a multi-contact connector from the ice maker to the back wall of the freezer, usually 6-9 wires. Pull that apart and check the cord side (ice maker side) for any corrosion. BE CAREFUL NOT TO TOUCH THE OTHER SIDE AS THERE IS LIVE 110V!!! If you don't see any corrosion, still try try disconnecting and reconnecting 5-10 times and see if that solves your problem. If you see corrosion, unplug the refrigerator before working on the back wall part of the connector. [This connector besides powering the ice maker also allows the ice maker to control the water valve which can't be inside the freezer]
Sep 03, 2016 | Samsung Refrigerators
Why water to icemaker , none to water dispenser , replaced water inlet valve fghs2655pf1 or 4a32520097
Refrigerator Not Making Ice? Water Inlet Valve Test - Fridge ...
? 2:47
https://www.youtube.com/watch?v=aXIX73EI1Z4
May 15, 2012 - Uploaded by RepairClinic.com
This video demonstrates how to test a water inlet valve on a refrigerator. ... Ice maker or water dispenser not ...
Refrigerator Ice And Water Dispenser Not Working - Repair ...
www.repairclinic.com/...---/Refrigerator-ice-and-water-dispenser-not-wo...
How It Works: Refrigerators · How It Works: Refrigerator Icemakers · How It Works: ... Most Frequent Causes for Refrigerator ice and water dispenser not working.
Nov 18, 2015 | Refrigerators
Fix icemaker
Start at the water valve at back of unit and work your way to the ice maker. Make sure the hose at the back of the frig isn't block. Also that the arm on the maker is down and in the on position. If all this checks, then go back to the solenoid that turns the water on and off to the ice marker.
Jan 03, 2015 | Refrigerators
Hello. My side by side refrigerator model MSD2434GE, serial no 11874215CG , I can not get water from the water dispensor, I ice dispensor works fine, I have tried pressing the lock three times but still...
There is valve at the back of the ice maker unit.This valve is the one unit with twin inlet.From one inlet the water enters the ice maker and from other inlet the water enters the water dispenser.so in that valve the ice maker side is working but water dispenser side is not working.Or the ice is got clogged/ over frosted in the water dispenser entering pipe.either the valve needs top be replaced or the water dispenser pipe needs to be checked.Calling service person is advisable.He will just check and confirm what is the issue, the water valve or the over frost build up in the water dispenser tube.and do as required to solve the issue/.If case if the water valve needs to be replaced then cost of water valve is approx $40.------------- this will help.Thanks.Helpmech.
May 29, 2011 | Maytag Refrigerators
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
Feb 14, 2010 | Refrigerators
It makes no ice cubes, but water still comes through door dispenser. Why? There appears to be no water getting to the ice making mechanism, however water is still coming out the door dispenser.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Nov 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker quit working but water side works still.
Sep 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I just replaced ice maker assembly because of broken plastic which holds drive gear. Now the new ice maker will not fill up with water. Water dispenser works fine.
Sep 02, 2009 | Refrigerators
Ice maker not working
The activity with the water supply could have loosened some sediment in the line stopping up the little wire screen filter going into the water inlet valve. I would disconnect it and inspect the screen and flush the water line out before re connecting. Assuming you have water at the water dispenser Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 30, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Ice maker is not making ice
Aug 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
100 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
