Question about Kenmore 22812 Bagged Canister Vacuum
Intermittent Power brush
I'm on my second Kenmore canister vac, and after a few years they have both had this problem. As you vacuum, the power brush is fine when you push it forward, but seems to die a little on the pull back. Almost like a connection is coming lose a little. Any suggestions of what I can do to fix, or tighten this? Thanks!!
  • 3 more comments
  • Lisa46062 Dec 18, 2007
    Thank you so much! I think it must have actually been the connector to the actual brush unit that was dirty, because cleaning those pins and the mating connector did the trick. (along with about a pound of lint from the inside or the unit)
    Thanks for your help!
    Thanks - The leads all looked ok, so I think dirt must have been the root cause of the problem.
  • LilTip Feb 03, 2008
    I followed the advise of cleaning the 360° swivel metal rings and bending the three flexible contacts to eliminate the intermittent power of my canister vac. It seemed to reduce the intermittent failures, but not completely eliminate them when the hose is pulled to "drag" the canister around the floor. Are there any other suggestions before I look into replacing this part?
  • Lisa46062 Feb 05, 2008
    Just an update - it turned out that the actual wire leading into the push unit was cracked. Now I don't know what I can do - short of replacing the wire. That's a little over my head.
    Thanks!
  • Lisa46062 Feb 07, 2008
    The wire that is cracked is the main power cord running down the metal shaft and into the carpet sweeper unit. I tried wrapping the cracked point with electrical tape, but that didn't really help correct the problem. Any tips? I don't know how it actually connects to the brush unit, so don't know if I can simply replace the cord, or if there is more involved.
    Thanks for any help you can offer. It's now very clean, and other than the electrical problem, working better than ever.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Dirt gets inside and causes an intermitten problem on the hose where it connects with the canister there is a plastic cover where the three pins stick out. on the cover are two tabs on either side. press both tabs together and CAREFULLY pull cover off. on the hose are three rings,clean them off with a rag,then put a small amount of grease on them. with this done go to the cover. you will see a small part with the three pins. on top of the pins are flexable leads. CAREFULLY pull up on them,but not much,only a little. now clean the inside of the cover. now lets put it together. first take the small part with the pins and place it on the hose making sure that the flex leads match with the rings. now place cover over both til it snaps into place. BY GETERDUN
Posted on Dec 18, 2007
  • 3 more comments
  • Geterdun Dec 18, 2007
    sorry about the spelling
    in the future please put down if vac is a canister or upright. also model numbers are important
  • Geterdun Feb 05, 2008
    LilTip, yes there is. 1) check the electrical contacts at the handle where it goes into the wand, 2) the contacts on the wand, 3) then the contacts from the wands to the power-mate. if any of them look brown in color then you may have some oxidation. you can try to clean it off with very fine sand paper. this might work, if not then just take it to sears
  • Geterdun Feb 06, 2008
    Lisa46062 Are the wires you talking about in the handle?
  • Geterdun Feb 07, 2008
    Lisa46062 Hi ! Not sure we can do this by just this web site. you may need to send me an email addr: or IM screen name, or phone #. It's up to you. You may want to go to www.sears.com first. click on parts,then put in your model #. A diagram will come up and all the parts are numbered. Then maybe you can show me exactly which part you are talking about and we can both be on sears.com together. If you are talking about the extension wand,there is a way to take it apart and fix it. It depends where on the wand the damage is.
    Let me know.
  • 21 Answers
I would first check where the hose attaches to the canister. There are 3 power leads; if one is bent, this might produce what you describe. You might even try wiggling this connection to see if it affects operation.
The other place you might see a problem is where the hose connects to the handle itself. There are 3 wires that attach from the hose. This is a bit tricky to remove as it's basically a force fit and take some effort to remove.
Posted on Dec 16, 2007
My husband accidentally dislodged the belt on my kenmore canister vac. how can we disassemble the head to put the belt back on?
There should be 4-5 screws on the bottom of the brush assembly, remove them and you will see the brush and belt, remove each end of the brush assembly they should lift up and out of the housing,and either replace or reailine the belt on the motor side of the housing.
Aug 25, 2014 | Kenmore Progressive Canister Vac Cleaner...
Brush works intermittedly - I've looked at the common solutions listed but none seem to work...shaking it & reseating the canister will get it working again sometimes but obviously that doesn't seem to...
I just had the same problem. I would turn on the vac, and it worked fine. When I turned on the brush it would work for a few seconds then shut off. Through troubleshooting I found out it had nothing to do with a bad power connection. By chance I took off the side HEPA filter to see how it looked. I realized that I have never changed it and that it was filthy. I removed it and turned on the vac, then the brush. It took a few tried, but the brush motor got back to full strength. I reassembled everything and it works fine now. It seems that the clogged filter was causing the brush motor to shut off. I'm running my vac w/o the HEPA filter while i wait for a new one to ship. Hope its the same prob for you!
Aug 30, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Kenmore 116.23513301
If the motor on the power brush is running the belt is bad, if the motor on the power brush only runs when you push the overload, the overload is bad.
Sep 14, 2009 | Kenmore 22812 Bagged Canister Vacuum
GE canister vac 106766 power not going to brush head
Try checking the hose connector cord (short cord from bezel outlet to hose). Also, check the prongs on on extension wands.
May 19, 2009 | GE 106766 Bagged Canister Vacuum
Kenmore vac producing burning odor
It sounds like you have bad carbon brushes on the motor. Get replacement brushes from a local vac shop, and take the unit apart. On each side of the motor their is a retangular piece of plastic with what looks like magnets in them. In most cases they are simply held by 2 screws. Replace these brushes and reasemble the unit. If the problem persists you have burned out the comutator on the motor and the whole thing must be replaced.
Apr 15, 2009 | Kenmore 22085 Bagged Canister Vacuum
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
Central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Jan 23, 2009 | Vacuums
Power brush not working well
You probably have a worn belt that drives the beater bar... 2 year old belts with reasonable use are more than likely due for a replacement. You should be able to get a replacement drive belt from Sears and change it yourself.. The baseplate of your power brush seperates and should provide access to the beater brush and drive pulley system.. Hope that helps..
Aug 25, 2008 | Kenmore 22812 Bagged Canister Vacuum
Kenmore 22812 Bagged Canister Vacuum Logo
109 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
