Question about Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
My trolling motor maxxum 74# thrust feels like i have broken something in the shaft. It is almost impossible to turn and everything in the head looks fine (cables,gears,etc.). What is in the shaft that could cause this and how do I disassemble the shaft to replace whatever is broken?
  • 76 Answers
Here's a schematic for your motor:
Maxxum 74 Bowmount
I suspect the the bearings and cups are damaged and binding the tubes. Have a look at key #'s95, 78, 58, 59, 78A, 79. as these are the actual brgs and cups.
Good luck on your repair!
Mike
Posted on Sep 26, 2009
Testimonial: "Great Thanks Alot"
My bow mount 43lb thrust foot controlled trolling motor is only working in one speed. It must be in rapid speed be cause the motor only works with selector switch on the rabbit and not on troll.
needs to go to a repair shop for a new resistor unit in the motor .or one of the wires going thru the shaft has broken .they fail dueto the constant flex from turning
Dec 16, 2015 | Boating
My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I have a minnkota maxxum 74lb thrust trolling motor. The pedal pin in the foot control keeps sliding out on one side and I have to push this back in to stabilize the pedal. Is there something...
Good day ,
The next time the pin comes out have a close look at it if it has little raised grooves in it that is what is supposed to hold it in.
if so put a little lock tight on the pin and push it back in it should hold again
good luck
Gordy
Nov 03, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I need to replace the bearings in my Maxxum 65lb Thrust trolling motor.
If you never did this before , I strongly advise take it to a local shop....if you don't seal it correctly, you will end up buying a new one for water getting in.... I fix alot of things on my boat but not the trolling motor....your choice....GL
Jul 10, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
TOOK THE BOLTS OUT OF MINN KOTA AND CANT GET THEM IN. 2 SHORT.
Hi!
Here's a schematic:
Max 74 Bowmount
Make sure the end housing #7has a small mark in it pointed to the bottom (towards the skeg). The bolts can be a pain to line up!
Also make sure the armature is all the way forward it can go....past the brushes is the toughest part to get through and lined up. Keep it up, you'll get it!
Best of luck
Mike
Jul 05, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Install
Click the link below, You do need to know your serial number thrust of motor and length of shaft as well how far away from trolling motor you will install your battery. This link is on Minn Kota Motors website under FAQ you can discuss with a service rep at Minn Kota please call 800-227-6433, but you will still need the information I asked earlier to come up with the answer.
http://www.minnkotamotors.com/_ui/sramk08/tpl/sramk_nohero_banner_faq-item.aspx?id=145&__taxonomyid=977
Apr 13, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
MINN kOTA 70 LB THRUST FOOT CONTROLLED TROLLING MOTOR
VONNY MY MOTOR DOES THE SAME THING AND I FOUND THAT THE DUST OF THE MAGNETS IN THE HEAD WAS CAUSING THE MOTOR TO STICK I CLEANED INSIDE WITH ELECTRICAL CLEANER AND IT STARTED TO WORK FINE BUT YOU MAY HAVE SOMETHING ELSE GOING ON AND ALSO MAY SURE YOU ARE NOT COVERED UNDER WARRANTY IF YOU JUST GOT THE BOAT
Jan 07, 2008 | Minn Kota Maxxum 70 Universal Motor/Sonar...
Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
776 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
